Dashboard blocks disappear with Safari IOS
Post Reply
davesdome
Post by davesdome »
This problem only appears when using Safari on my iPhone or iPad. Dashboard blocks can jump to new locations or disappear entirely. I don’t experience this with Safari on MacOS or Windows browsers.
mikeysklar
Re: Dashboard blocks disappear with Safari IOS
Post by mikeysklar »
I had contacted the Adafruit IO team about the sidebar not showing up and they opened an issue. It was easily replaceable.
Can you post screenshots from your browser and phone highlighting the discrepancy you are seeing?
davesdome
Post by davesdome »
The first photo shows a correct rendering (sometimes things seem to work correctly). The second photo shows the problem which is more typical of what I see. After seeing the correctly rendered page, I refreshed the page and got the faulty rendering. Subsequent refreshes mostly continue to be faulty. Sometimes I’ll get a correct rendering again.
mikeysklar
Thank you for these screen shots.
I'll ask adafruitio to comment.
Also can you please add:
1) iOS versions
2) phone / ipad models
3) Does chrome display the blocks correctly on the above devices?
lorennorman
Post by lorennorman »
Hello davesdome! Sorry you're having this issue, I'd like to help. I haven't been able to reproduce this yet, but I can see some permissions errors related to this dashboard and its feeds.
When your blocks aren't appearing, can you confirm that you are logged in at that time? (Touch the little "hamburger menu" and make sure it says "Hello, [Your Name]" (not "sign up or log in" or whatever.)
You might also toy with "privacy" and "sharing" settings for the dashboard and its feeds. I wondering if, for instance, the problem goes away entirely if the dashboard and all its feeds are set to "public" visibility.
Also, what happens if you rotate the phone to landscape mode? (Dashboard should do a re-layout for a larger canvas size, but maybe we'll see some block visibility change for a clue.)
To be clear, this is mere experimentation to help us narrow down the issue. When we figure out what's happening we'll fix it and you won't have to do such shenanigans. I'm only asking because it might be very helpful to the debugging process.
Samourais
Post by Samourais »
I have the same problem also on Mac 17.7.2, Safari 17.2.1. I have the problems on iPad and iPhone, both on 17.3. The first block is always present.
Good display
Good display
Capture d’écran, le 2024-02-01 à 14.19.51.png (37.55 KiB) Viewed 434 times
Bad display of dashboard
Capture d’écran, le 2024-02-01 à 14.20.02.png (16.46 KiB) Viewed 434 times
Samourais
Post by Samourais »
On Firefox it is working correctly. Firefox 121.0 on Mac osx 12.7.2.
davesdome
Post by davesdome »
To answer some previous questions…
- The iPhone 13 Pro is running iOS version 17.3
- The iPad Pro (4th gen) is running the same version.
- Chrome on the iPad also exhibits this behavior.
- I’m logged into the account when the problem presents.
- I did discover that rotating to horizontal on the iPhone does resolve this issue and if I then rotate back to vertical the blocks continue to be visible until I refresh the page, then the problem presents once again.
- Experimenting with rotation on the iPad doesn’t resolve the issue.
- Making all feeds public doesn’t resolve issue.
sambhit08
Post by sambhit08 »
QCWA108
Post by QCWA108 »
The problem continues. Any updates on a resolution?
lorennorman
I think we may have just fixed this! Could someone give it a test and let us know?
We finally reproduced the issue and chased it down. As of 5 minutes ago it no longer occurs on the iOS and macOS versions of Safari where we isolated it.
Thank you so much for your patience on this insidious issue, everyone. We'll keep an eye on this post in case there's more to be done.
QCWA108
Post by QCWA108 »
It appears to be working fine now. Thanks for getting it fixed!!!
patrikkpaul
Post by patrikkpaul »
lorennorman
patrikkpaul You'll need to provide more detail if you'd like me to look into something for you.
Post Reply
Return to “Internet of Things: Adafruit IO and Wippersnapper”
