Reverse engineering Industrial Beagleboard
Post Reply
ac2ev
Post by ac2ev »
We recently retired some equipment and I got to take it home to play with. The device in question will be described as a custom beagle Bone based system. The manufacturer has a custom board with lots of I/O to play with. This particular system uses a SD card so that's made my job a bit easier. I've gone through and disabled most of their custom programs to get it close to a bare Beagle Board but none of the standard Beagle development is there. On other units I've tried installing a standard image, I may have posted about it here. That removes all the drivers and leaves me with a non working LCD.
I have root on the device. SSH, ethernet, console, LCD, keyboard are working. It does NOT like having lightdm and XFCE running. It froze up, so I'm back to console only.
[    0.000000] Linux version 4.4.70-bone-rt-r17 (daven@dmccallaVM) (gcc version 5.4.1 20170404 (Linaro GCC 5.4-2017.05) ) #211 PREEMPT RT Fri Nov 6 09:39:55 CST 2020
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: TI AM335x BeagleBone Green
[    0.000000] cma: Reserved 24 MiB at 0x9e800000
What I'm looking to currently accomplish is a way to map the GPIO to the various connectors. I don't know an easy way to do this. I started to do 'cat value' on the various items in sys/class/gpio but that is excruciatingly slow. It took 15 minutes to find that the e-stop switch was mapped to gpio65.
The version of cat installed has no options:
cat --help
BusyBox v1.22.1 (Debian 1:1.22.0-9+deb8u1) multi-call binary.
Usage: cat [FILE]...
Concatenate FILEs and print them to stdout
root@THE-DEVICE:/sys/class/gpio# cd gpio65
root@THE-DEVICE:/sys/class/gpio/gpio65# ls
active_low  device      edge        power       subsystem   uevent      value
There must be an easier way.
DMESG.txt
(28 KiB) Downloaded 2 times
ac2ev
Re: Reverse engineering Industrial Beagleboard
Post by ac2ev »
The issue I'm dealing with is that because the system uses Busybox not all functions are enabled and as such I can't install python-pip as it requires updating libc6 which errors and I'm not sure how to "fix" this.
readlink: invalid option -- 'm'
Usage: readlink [-fnv] FILE
Display the value of a symlink
	-f	Canonicalize by following all symlinks
	-n	Don't add newline
	-v	Verbose
dpkg: error processing archive /var/cache/apt/archives/libc6_2.19-18+deb8u10_armhf.deb (--unpack):
 subprocess new pre-installation script returned error exit status 1
Errors were encountered while processing:
Post Reply
Return to “Beagle Bone & Adafruit Beagle Bone products”
