Anyone else getting a battery level reading on Feather ESP32 V2 GPIO35 that is 1/4 the actual value??
Post Reply
jpiatt
Post by jpiatt »
I'm using a Feather ESP32 V2 to report soil sensor readings from the Monk Makes Plant Monitor to my Home Assistant. I'm also monitoring the level of my 3.7v LiPoly battery using GPIO35 but my readings are consistently 1/4 of the actual voltage level (not 1/2 as the docs say it should be). I should mention that the battery hasn't really discharged at all since I started my testing because I just took the board off the USB tether yesterday and I'm keeping it in a deep sleep, only waking every hour for 90 seconds to take readings and report them. The raw value I'm getting for a fully charged battery is about 1.045 volts, which X4 would be the correct value of about 4.2.
Anyway, I'm asking in case something changed in the board. Anyone else seeing this? I'm using the right pin, yeah?
Here's the sensor definition I've coded for it:
  - platform: adc
    pin: GPIO35
    filters:
      - multiply: 4 # supplied value is 1/4 actual voltage (docs say 1/2 but ...)
    state_topic: ${io_username}/feeds/spike-batterylevel
    on_value:
      - then:
        - mqtt.publish:
            payload: x
    update_interval: ${update_interval}
mikeysklar
Re: Anyone else getting a battery level reading on Feather ESP32 V2 GPIO35 that is 1/4 the actual value??
Post by mikeysklar »
What code is running Feather V2?
If you remove the deep sleep do you still see the same 1/4 value instead of half value for the battery reading?
jpiatt
Post by jpiatt »
Sorry. I just saw this today as I forgot to tick the button for reply notifications. Anyway, the Feather is running ESPHome. I did finally try it without the sleep code and got the same result. However, until today I hadn't really had a chance to see what it reports for a partially discharged LiPoly. It reads the same value as a fully charged one (1.045V)! So something isn't right.
I'm gonna load some simple Arduino code and see what it shows then.
mikeysklar
Good idea to try the Arduino code to compare. This could be an ESPHome specific issue.
jpiatt
Post by jpiatt »
So, it turns out the ADC on ESP32 is capped at ~1.1V for measuring input voltage. ESPHOME offers an "attenuation" keyword with several possible settings to compensate and, most helpfully one simply stated as "attenuation: auto". Once I implemented this change, I was indeed getting a reading that is one half the expected value.
mikeysklar
GTK, Thank you for the followup on this.
Post Reply
