Matrix Portal (64 x 32, 4mm pitch) dead 1.5 rows and one half-column stuck in blue
Post Reply
guydav
Post by guydav »
A while back I purchased (from Digikey, linked from the Adafruit website) a Matrix Portal starter kit, with the 64 x 32 mm Matrix and MatrixPortal. I did some initial programming and set it aside. When I came back to it recently, I noticed that the colors are off -- 1.5 rows are dead, half a column is stuck in blue, and other pixels have their colors off. I don't know what I could have done to cause this or what I could do to fix it -- I tried unplugging and plugging back in, reflashing my code, and changing power sources, but nothing seems to make a difference. I'm attaching pictures below of full red/green/blue, the row stuck in blue as it's booting up, and the back of the board.
Thanks in advance for your help,
Guy
guydav
Re: Matrix Portal (64 x 32, 4mm pitch) dead 1.5 rows and one half-column stuck in blue
Post by guydav »
Two more photos I couldn't upload to the first post:
adafruit_support_carter
Try the simpletest UF2 downloaded from here (for the 64x32):
https://learn.adafruit.com/adafruit-mat ... /downloads
Double press reset to get BOOT folder
Drag downloaded UF2 to BOOT folder
Do the display issues still appear on the matrix?
guydav
Post by guydav »
Unfortunately, the issues persist. See the image below -- dead row in the bottom, dead row in the top (missing pixel in UIT), half-column stuck in blue in the middle, and text that should be white in yellow (upper-left corner can't show blue).
Hmm. Yah, looks like same general issue.
Does reseating the MatrixPortal help at all? Or change things?
guydav
Post by guydav »
Unfortunately not -- I tried to remove and replace it, and the same thing happened. I thought about inserting it into the second 16-pin socket, but it won't fit there with where the 4-pin power connector is in the middle. I also tried different power supplies -- same outcome.
OK, seems most likely something with the RGB matrix. Let's send a replacement.
Send an email to [email protected] with a link to this thread and they can help get you a replacement 64x32 4mm pitch RGB Matrix.
guydav
Post by guydav »
Thank you very much, send an email!
Post Reply
