QTPY-S3 RESET always starts bootload
Adafruit's tiny microcontroller platform. Please tell us which board you are using.
Post Reply
alainsam
Post by alainsam »
I am trying to run a sketch on qtpy-s3 The sketch compiles and downloads correctly but when I want to start it on the board by pushing the Reset button (not double push) I get the UF2 bootloader instead of running the program. What is wrong?
TinyUF2 Bootloader 0.10.2 - tinyusb (0.12.0-203-ga4cfd1c69)
Model: Adafruit QT Py ESP32-S3
Board-ID: ESP32S3-QTPy-A
Date: Jun 24 2022
adafruit_support_carter
Re: QTPY-S3 RESET always starts bootload
Are you seeing the same behavior if you upload the basic Blink example sketch?
alainsam
Post by alainsam »
No, the Neopixel is blinking correctly with the blink program.
Here is the code that produces the problem:
#include <Arduino.h>
// How many internal neopixels do we have? some boards have more than one!
#define NUMPIXELS        1
Adafruit_NeoPixel pixels(NUMPIXELS, PIN_NEOPIXEL, NEO_GRB + NEO_KHZ800);
int dutyPercent =50;//Percent off<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
// Use 12-bit precision for LEDC timer
#define LEDC_TIMER_12_BIT 12
// Use 4 Hz as the LEDC base frequency
int freq= 4;//Hz <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
#define LEDC_BASE_FREQ freq
// Define the LED pin (replace with LED_BUILTIN constant for built-in LED)
#define LED_PIN 2 //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
//NeoPix setup
	#if defined(NEOPIXEL_POWER)
	pinMode(NEOPIXEL_POWER, OUTPUT);
	digitalWrite(NEOPIXEL_POWER, HIGH);
	#endif
	pixels.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
	pixels.setBrightness(200); // not so bright  // Setup timer with given frequency and resolution, and attach it to the LED pin
//setup PWM
    ledcAttachPin(LED_PIN, LEDC_TIMER_12_BIT);
    // Set the LED duty cycle to 50% (4095 corresponds to 100%)
    ledcWrite(LED_PIN, 4095/(100/dutyPercent));
       pixels.fill(0x000000);//light off
      pixels.show();
	  Serial.println("BLK");
	  delay(1000*(1/(freq*(dutyPercent/100))));//
    pixels.fill(0xFF0000); // Light on
    pixels.show();
	 delay(1000*(1/(freq-1/freq*(dutyPercent/100))));//
	Serial.println("RED");
alainsam
Post by alainsam »
Oops! My mistake in the delays, they should have used division instead of multiplication. No wonder my bank account is in trouble...
Is that also fixing the resetting into bootloader behavior?
alainsam
Post by alainsam »
unfortunately no...
Try adding a call to Serial.begin in setup(). There are Serial.prints in loop(), but no call to Serial.begin().
That's just a guess. Not sure what would be causing that behavior.
alainsam
Post by alainsam »
It still does the same with or without the Serial.begin.
Not sure then.
Start with the Blink example that is known to be working and slowly modify it towards your sketch that is not working. Find out at what point (what code added) causes the behavior to show up.
alainsam
Post by alainsam »
The error came from:
When dutyPercent=0 (No blink) and somehow the boatload appears...
The division by zero is causing a fault that triggers the reset. Not sure why it resets into bootloader mode though. But easy enough to add code protect against a divide by zero.
Post Reply
Return to “Trinket ATTiny, Trinket M0”
