Adafruit MatrixPortal M4 crashes Windows Explorer
Post Reply
algaib
Post by algaib »
I have just bought a new Adafruit MatrixPortal M4. When I connect it via a good data-enabled USB, I see the MATRIXBOOT drive when I double-press the reset button (the light is green), but when I click on the drive in the Windows Explorer, the file path bar fills green like a progress meter for a long time and seems to stop at around 98%. When I click anywhere on the explorer, it crashes, every time.
I've tried restarting the computer etc, but it makes no difference. I'm using Windows 10.
I checked the troubleshooting guide here: https://learn.adafruit.com/welcome-to-c ... leshooting
But I don't have any of the apps installed it suggests to stop. I tried exiting Malwarebytes and Samsung Magician, but it didn't make any difference.
Any thoughts or suggestions? Thanks!
algaib
Re: Adafruit MatrixPortal M4 crashes Windows Explorer
Post by algaib »
Update: I managed to get it working in Arduino IDE and upload some code, but now when I connect to the computer, it says Windows does not recognize the device.
Is it just a faulty device? Is there something I can do to 'reset' it?
adafruit_support_carter
That can sometimes happen. And Windows in general can get confused due to all the connects/disconnects that might happen when uploading new code, etc.
Is it reliably taking new Arduino sketch uploads?
Speedy_VI
Post by Speedy_VI »
algaib wrote: Wed May 15, 2024 7:30 am I tried exiting Malwarebytes and Samsung Magician, but it didn't make any difference.
I had the same problem with a Feather M0 WiFi. The FEATHERBOOT drive would show up in an Explorer window but I could not click on it select any files, view its properties, or look at it in Disk Manager. Someone from Adafruit support asked if I had Samsung Magician running (I did). He said that program can interfere with the Boot drive mounting properly and I should uninstall Samsung Magician.
This did not seem likely to me but I did exit Magician. That did not fix the problem. Then I uninstalled Magician and the problem vanished. I then went and tested this on another machine, also running Windows 10 with Samsung Magician installed. Same exact thing. I could not do anything with the FEATHERBOOT drive in Windows except look at the Explorer window until I totally uninstalled Samsung Magician. I don't know what Magician is doing, even when the program is not running, but it is doing something that causes this problem.
BTW - I also have Malware Bytes running and it has not caused any problems.
algaib
Post by algaib »
adafruit_support_carter wrote: Wed May 15, 2024 1:41 pm That can sometimes happen. And Windows in general can get confused due to all the connects/disconnects that might happen when uploading new code, etc.
It did once, but now it's completely unrecognized by windows and just crashes the explorer unfortunately
algaib
Post by algaib »
Speedy_VI wrote: Wed May 15, 2024 4:36 pm
Interesting, I'll try uninstalling Magician and see what happens. Thanks!
Post Reply
