VL53L1X begin Freezes if not connected
Post Reply
matt_toplack
Post by matt_toplack »
Hello!
I am trying to make my code for the VL53L1X as robust as possible, which includes being able to recover if one or more of the sensors I have connected is not connected, is damaged, etc. With the VL53L0X, if there is no sensor connected, it will fail after a short while, allowing me to handle that failure and move on. Unfortunately, it seems that the VL53L1X's library is not set up this way and instead blocks my code from continuing. Any suggestions on modifying the library?
adafruit_support_carter
Re: VL53L1X begin Freezes if not connected
Are these Arduino or CircuitPython libraries?
matt_toplack
Arduino
Does the behavior show up running the simple example from the library?
https://github.com/adafruit/Adafruit_VL ... letest.ino
That only prints "Adafruit VL53L1X sensor demo" and then nothing else? And works as expected when the VL53L1X *is* connected?
Post Reply
