Weather display matrix (Adabox 016)
Post Reply
jcalvin
Post by jcalvin »
Back when Adabox 16 came out, I tried to add some forecast data John Park's "Weather Display Matrix" code. But, there just wasn't enough memory on the M4 Matrix Portal to manage what I wanted to do. Now there's an ESP32-S3 version of the Matrix Portal with LOTS of memory!
Attached is a .zip of all the files for a version of John Park's original weather display with the following modifications:
- adds forecast information to the display (if sufficient memory)
- adds ability to control which bits of data are displayed (from a settings file)
- adds ability to change the strings displayed with the data (display information in German if you like) via settings
- can change the colors of strings displayed via settings file
- assumes CircuitPython 9 or later
Matrix_Portal_Weather.zip
(136.89 KiB) Downloaded 1 time
The settings.toml file must be updated with your particulars. The file weather_settings.py should have the latitude, longitude, and time zone set for your weather display.
See John's original learn guide here: https://learn.adafruit.com/weather-display-matrix
bidrohini1
Re: Weather display matrix (Adabox 016)
Post by bidrohini1 »
Thanks for sharing your experience.
Post Reply
Return to “AdaBox! Show us what you made!”
