RP2040 USB host question
Post Reply
heliophagus
Post by heliophagus »
Hi! I want to use the RP2040 USB host as part of a datalogger with a USB thumb drive & have an embarrassingly n00b question.
In the datalogger example, it seems that fatfs is defined as a FatVolume from SdFat, & f_log is defined as File32. f_log is then opened so:
f_log = fatfs.open(LOG_FILE, O_WRITE | O_APPEND | O_CREAT);
and then closed with
f_log.close();
Unfortunately I can't find a list of available commands & their parameters (other than the above code) anywhere. I've Googled & Kagi'd for over a day with no results. Basically, I'd like to search for a filename on the USB, & if it exists, choose another candidate filename until I find a unique name. Then, open that & write (append) to it for a few minutes or hours. Then, finally, close the file. Very simple!
I'd HUGELY appreciate a link to the available commands - for example, a Boolean function that returns whether a given filename exists.
BTW, Am I correct in assuming that filenames are limited to the 8.3 format?
Thanks in advance! --- John
T_Mo
Re: RP2040 USB host question
Post by T_Mo »
Are you referring to this product?
https://www.adafruit.com/product/5723
heliophagus
Yes indeed! I was lucky enough to get one before they ran out of stock. It sees the supply chain issues are still with us.
It's been a while since I've been down in the trenches with coding, & had lost track of the fact that the Adafruit TinyUSB library inherits its commands etc. from the SdFat library, so I'm wading through the swamps of the SdFile.h include. It would be great if an informative text intro to the commands existed, with examples. But if that's not the case, I'll eventually get things working. Though at the cost of many hours of trial-and-error.
If anyone knows of a good intro to the SD/USB file commands with examples, please let me know! I'm certainly not the only person who could use a guide to this area.
adafruit_support_mike
In CircuitPython, the SDFat interface lives in the 'storage' module:
https://docs.circuitpython.org/en/lates ... age.VfsFat
To test if a file exists, you can use the 'os' module and the .stat() command:
https://docs.circuitpython.org/en/lates ... ml#os.stat
If the file exists you'll get a data structure of metadata about it. If it doesn't exist the interpreter will thrown an OSError exception:
import os
def file_existsP( f ):
	try:
		e = os.stat( f )
		result = True
	except:
		result = False
	return result
The function name ends with P because I code with a slight LISP.. test functions like that are formally known as 'predicates' and the captial P is as close as most languages will let you get to putting a question mark in a symbol name.
heliophagus
Thanks, but I should have made it clearer that I am using the standard Arduino language.
In that case you'll want the SDFat library documentation:
https://github.com/greiman/SdFat
Post Reply
Return to “Arduino”
