display options for SHT41 Trinkey - USB Temperature and Humidity Sensor
Post Reply
raspieit
Post by raspieit »
first time tinkerer here...
i'd like some help in determining a small screen that would be simple (without soldering) to use with SHT41 usb.
thanks...
raspieit
Re: display options for SHT41 Trinkey - USB Temperature and Humidity Sensor
Post by raspieit »
yes, that's the device.
but i'm searching for some kind of display that can be used with it.
dastels
Post by dastels »
The problem is that there's no connection for a display. It would need wither I2C or SPI, neither of which are accessible. Unless.. you wanted to try soldering onto the pins of the SAMD21 chip. Tricky with experience on a good day.
michaelmeissner
Post by michaelmeissner »
Another thought is to move away from a Trinkey and move to a platform with more options. You will need to combine two boards, but in some cases that can be done without soldering.
Lets see, an ESP32-S3 feather board with built-in TFT display and SHT41 Stemma board should do nicely in theory. Unlike the ESP32-S2 boards, the ESP32-S3 boards have native USB support (much like the trinkeys do). It also has the Stemma Qwiic connector on board, so you can hook up the sensor:
raspieit
Post by raspieit »
thanks for that suggestion of a complete system.
in fact, i was searching for a board with built-in small display.
i'll have to get a few parts and start tinkering...
Post Reply
