Qt Py ESP32-S2 Arduino Pinout
Post Reply
davidwalker555
Post by davidwalker555 »
Hi all. Does anybody know the in designators to use for Arduino IDE? The documentation, including the pinout diagram only shows the GPIO and CircuitPython designators. For example, if I want to write Arduijo code for pin A0, what pin should I declare in the IDE?
mikeysklar
Re: Qt Py ESP32-S2 Arduino Pinout
Post by mikeysklar »
You can reference A0.
With Arduino there is a pins_arduino.h that has all the pin names that are included with the board support package.
$HOME/Library/Arduino15/packages/esp32/hardware/esp32/3.0.2/variants/adafruit_qtpy_esp32s2/pins_arduino.h
generated example code:
  // Initialize serial communication for debugging
  Serial.begin(115200);
  // Set pin A0 as an input
  pinMode(A0, INPUT);
  // Read the analog value from pin A0
  int analogValue = analogRead(A0);
  // Print the analog value to the Serial Monitor
  Serial.print("Analog value: ");
  Serial.println(analogValue);
  // Add a small delay before the next reading
  delay(1000);
pins_arduino.h for this board Qt Py ESP32-S2:
pins_arduino.h
(1.71 KiB) Downloaded 3 times
davidwalker555
This is a very helpful reply thank you!
Post Reply
Return to “Itsy Bitsy Boards”
