RGB Matrix with Pi 4 B
Post Reply
Cheezheadsrule
Post by Cheezheadsrule »
I've used 3 pis, so I don't believe that's the issue. When I plug the display in and run my code, I either get nothing or random colors. I've unplugged, replugged a bunch of times. Is either the display or matrix bad?
Cheezheadsrule
Re: RGB Matrix with Pi 4 B
Franklin97355
Post by Franklin97355 »
Have you used the other pis with the matrix and had it work? Also, have you loaded the new pi with a current version of the software?
Cheezheadsrule
I've tried 3 other pis and had same results. Yes I've done all the updates.
Franklin97355
What are you using to power this?
Cheezheadsrule
Cheezheadsrule
If I wiggle the bonnet the display shows different colors but still all gibberish. Is the bonnet bad?
Franklin97355
Can you post pictures of the bonnet from both sides?
Cheezheadsrule
Is this helpful?
Cheezheadsrule
Should I just order a replacement? I'm pretty sure it's defective but waiting for a exchange is taking too long at this point.
Franklin97355
I was looking for the bottom side to check for soldering defects. Go ahead and contact [email protected] with a link to this thread; they will replace it and decide if they want you to return it.
Cheezheadsrule
Thank you for all your help!
Post Reply
Return to “Adafruit Raspberry Pi® accessories”
