AI bear that failed to run successfully
This is a special forum devoted to educators using Adafruit and Arduino products for teaching.
walkerjohnson
Post by walkerjohnson »
# SPDX-FileCopyrightText: 2023 Melissa LeBlanc-Williams for Adafruit Industries
import threading
import os
import sys
import time
import random
import configparser
from tempfile import NamedTemporaryFile
import azure.cognitiveservices.speech as speechsdk
from openai import OpenAI
import board
import digitalio
from adafruit_motorkit import MotorKit
from listener import Listener
API_KEYS_FILE = "~/keys.txt"
# ChatGPT Parameters
SYSTEM_ROLE = (
    "You are a helpful voice assistant in the form of a talking teddy bear"
    " that answers questions and gives information"
CHATGPT_MODEL = "gpt-3.5-turbo"
WHISPER_MODEL = "whisper-1"
# Azure Parameters
AZURE_SPEECH_VOICE = "en-GB-OliverNeural"
DEVICE_ID = None
# Speech Recognition Parameters
ENERGY_THRESHOLD = 1000  # Energy level for mic to detect
RECORD_TIMEOUT = 30
# Motor Parameters
ARM_MOVEMENT_TIME = 0.5
BASE_MOUTH_DURATION = 0.2  # A higher number means slower mouth movement
SPEECH_VARIANCE = 0.1  # Higher allows more mouth movement variance.
                       # It pauses for BASE_MOUTH_DURATION ± SPEECH_VARIANCE
MOTOR_DUTY_CYCLE = 1.0  # Lower provides less power to the motors
# Do some checks and Import API keys from API_KEYS_FILE
config = configparser.ConfigParser()
username = os.environ["USER"]
user_homedir = os.path.expanduser(f"~{username}")
API_KEYS_FILE = API_KEYS_FILE.replace("~", user_homedir)
def get_config_value(section, key, min_length=None):
    if not config.has_section(section):
        print("Please make sure API_KEYS_FILE points to "
              f"a valid file and has an [{section}] section.")
        sys.exit(1)
    if key not in config[section]:
        print(
            f"Please make sure your API keys file contains an {key} under the {section} section."
        sys.exit(1)
    value = config[section][key]
    if min_length and len(value) < min_length:
        print(f"Please set {key} in your API keys file with a valid key.")
        sys.exit(1)
    return config[section][key]
print(os.path.expanduser(API_KEYS_FILE))
config.read(os.path.expanduser(API_KEYS_FILE))
openai = OpenAI(
    # This is the default and can be omitted
    api_key=get_config_value("openai", "OPENAI_API_KEY", 10)
openai.api_base = "https://www.gptapi.us/v1"  # 设置新的 API 基础地址
speech_key = get_config_value("azure", "SPEECH_KEY", 15)
service_region = get_config_value("azure", "SPEECH_REGION")
speech_config = speechsdk.SpeechConfig(subscription=speech_key, region=service_region)
speech_config.speech_synthesis_voice_name = AZURE_SPEECH_VOICE
def sendchat(prompt):
    response = ""
    stream = openai.chat.completions.create(
        model=CHATGPT_MODEL,
        messages=[
            {"role": "system", "content": SYSTEM_ROLE},
            {"role": "user", "content": prompt},
        stream=True,
    # Send the heard text to ChatGPT and return the result
    for chunk in stream:
        if chunk.choices[0].delta.content is not None:
            response += chunk.choices[0].delta.content
    return response
def transcribe(wav_data):
    # Read the transcription.
    print("Transcribing...")
    attempts = 0
    while attempts < 3:
        try:
            with NamedTemporaryFile(suffix=".wav") as temp_file:
                result = openai.Audio.translate_raw(
                    WHISPER_MODEL, wav_data, temp_file.name
                return result["text"].strip()
        except (openai.error.ServiceUnavailableError, openai.error.APIError):
            time.sleep(3)
        attempts += 1
    return "I wasn't able to understand you. Please repeat that."
class Bear:
    def __init__(self, azure_speech_config):
        kit = MotorKit(i2c=board.I2C())
        self._arms_motor = kit.motor1
        self._mouth_motor = kit.motor2
        # Setup Foot Button
        self._foot_button = digitalio.DigitalInOut(board.D16)
        self._foot_button.direction = digitalio.Direction.INPUT
        self._foot_button.pull = digitalio.Pull.UP
        self.do_mouth_movement = False
        self._mouth_thread = threading.Thread(target=self.move_mouth, daemon=True)
        self._mouth_thread.start()
        if DEVICE_ID is None:
            audio_config = speechsdk.audio.AudioOutputConfig(use_default_speaker=True)
        else:
            audio_config = speechsdk.audio.AudioOutputConfig(device_name=DEVICE_ID)
        self._speech_synthesizer = speechsdk.SpeechSynthesizer(
            speech_config=azure_speech_config, audio_config=audio_config
        self._speech_synthesizer.synthesizing.connect(self.start_moving_mouth)
        self._speech_synthesizer.synthesis_completed.connect(self.stop_moving_mouth)
    def start_moving_mouth(self, _event):
        self.do_mouth_movement = True
    def stop_moving_mouth(self, _event):
    def deinit(self):
        self._mouth_thread.join()
        self._arms_motor.throttle = None
        self._mouth_motor.throttle = None
        self._speech_synthesizer.synthesis_started.disconnect_all()
        self._speech_synthesizer.synthesis_completed.disconnect_all()
    def _move_arms_motor(self, dir_up=True):
        direction = -1 if dir_up else 1
        self._arms_motor.throttle = MOTOR_DUTY_CYCLE * direction
        time.sleep(ARM_MOVEMENT_TIME)
        # Remove Power from the motor to avoid overheating
    def _move_mouth_motor(self, dir_open=True):
        duration = (
            BASE_MOUTH_DURATION
            + random.random() * SPEECH_VARIANCE
            - (SPEECH_VARIANCE / 2)
        # Only power the motor while opening and let the spring close it
        self._mouth_motor.throttle = MOTOR_DUTY_CYCLE if dir_open else None
        time.sleep(duration)
        # Remove Power from the motor and let close to avoid overheating
    def foot_pressed(self):
        return not self._foot_button.value
    def move_mouth(self):
        print("Starting mouth movement thread")
        while True:
            if self.do_mouth_movement:
                self._move_mouth_motor(dir_open=True)
                self._move_mouth_motor(dir_open=False)
    def move_arms(self, hide=True):
        self._move_arms_motor(dir_up=hide)
    def speak(self, text):
        result = self._speech_synthesizer.speak_text_async(text).get()
        # Check result
        if result.reason == speechsdk.ResultReason.SynthesizingAudioCompleted:
            print("Speech synthesized for text [{}]".format(text))
        elif result.reason == speechsdk.ResultReason.Canceled:
            cancellation_details = result.cancellation_details
            print("Speech synthesis canceled: {}".format(cancellation_details.reason))
            if cancellation_details.reason == speechsdk.CancellationReason.Error:
                print("Error details: {}".format(cancellation_details.error_details))
def main():
    openai.api_base = "https://www.gptapi.us/v1"  # 设置新地址
    listener = Listener(openai.api_key, ENERGY_THRESHOLD, RECORD_TIMEOUT)
    bear = Bear(speech_config)
    transcription = [""]
    bear.speak(
        "Hello there! Just give my left foot a squeeze if you would like to get my attention."
    while True:
        try:
            if bear.foot_pressed():
                bear.speak("How may I help you?")
                listener.listen()
            if listener.speech_waiting():
                bear.speak("Let me think about that")
                bear.move_arms(hide=True)
                text = listener.recognize()
                if text:
                    transcription.append(text)
                    print(f"Phrase Complete. Sent '{text}' to ChatGPT.")
                    chat_response = sendchat(text)
                    transcription.append(f"> {chat_response}")
                    print("Got response from ChatGPT. Beginning speech synthesis.")
                    bear.move_arms(hide=False)
                    bear.speak(chat_response)
                os.system("clear")
                for line in transcription:
                    print(line)
                print("", end="", flush=True)
                time.sleep(0.25)
        except KeyboardInterrupt:
            break
    bear.deinit()
if __name__ == "__main__":
    main()
walkerjohnson
Re: AI bear that failed to run successfully
pi@raspberrypi:~ $ source ~/myenv/bin/activate
(myenv) pi@raspberrypi:~ $ python3 assistant.py
/home/pi/keys.txt
ALSA lib confmisc.c:1369:(snd_func_refer) Unable to find definition 'cards.0.pcm.front.0:CARD=0'
ALSA lib conf.c:5180:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5703:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM front
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib confmisc.c:1369:(snd_func_refer) Unable to find definition 'cards.0.pcm.surround51.0:CARD=0'
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM surround21
ALSA lib confmisc.c:1369:(snd_func_refer) Unable to find definition 'cards.0.pcm.surround40.0:CARD=0'
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM surround40
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM surround41
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM surround50
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM surround51
ALSA lib confmisc.c:1369:(snd_func_refer) Unable to find definition 'cards.0.pcm.surround71.0:CARD=0'
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM surround71
ALSA lib confmisc.c:1369:(snd_func_refer) Unable to find definition 'cards.0.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM iec958
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM spdif
ALSA lib confmisc.c:1369:(snd_func_refer) Unable to find definition 'cards.0.pcm.hdmi.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM hdmi
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
ALSA lib pcm_oss.c:397:(_snd_pcm_oss_open) Cannot open device /dev/dsp
ALSA lib pcm_a52.c:1001:(_snd_pcm_a52_open) a52 is only for playback
ALSA lib confmisc.c:1369:(snd_func_refer) Unable to find definition 'cards.0.pcm.iec958.0:CARD=0,AES0=6,AES1=130,AES2=0,AES3=2'
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM iec958:{AES0 0x6 AES1 0x82 AES2 0x0 AES3 0x2 CARD 0}
ALSA lib confmisc.c:160:(snd_config_get_card) Invalid field card
ALSA lib pcm_usb_stream.c:482:(_snd_pcm_usb_stream_open) Invalid card 'card'
ALSA lib pcm_dmix.c:972:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
ALSA lib pcm_dmix.c:999:(snd_pcm_dmix_open) unable to open slave
Return to “For Educators”
