Dead RP2350 board
- tcroswell
Dead RP2350 board
Hi;
I recently received order #3373482. Unfortunately, one of the two RP2350 boards seems to be dead. I tried to install the basic 'blinky' example but it would not enter bootsel mode.
I wired the 'Run' and GND together to force a hard reset but that did not work either.
The other board worked immediately.
I tried a couple of different USB cables and the working board used either one w/o a problem while this made no difference to the board I suspect is bad.
Unless you have some other ideas, I would like to return the bad board in exchange for another one.
Thanks,
Tom
Thanks,
Tom
- Franklin97355
Re: Dead RP2350 board
Do you still have the bag it came in?
- tcroswell
Yes, I put the board back into the bag.
- Franklin97355
What are the numbers on the bag (for tracing the manufacturing trail)?
- tcroswell
The bag is labeled as a Raspberry Pi Pico 2 - RP2350.
There are two sets of numbers:
P6006 (upper right corner)
and
K18163-A
and
K18163-A
- tcroswell
As I mentioned, I have a second RP:2350 which seems to work as expected.
It has the same numbers on the bag as the one that does not work.
- adafruit_support_carter
Was this done because the BOOTSEL button was not working as expected?I wired the 'Run' and GND together to force a hard reset but that did not work either.
You're holding BOOTSEL while inserting the USB cable?
The other Pico works as expected in that regard? (can get the RPI-RP2 folder)
Just curious about the bootloader mode behavior at this point. Since the Pico has a ROM bootloader, should be pretty unbrickable.
- tcroswell
I followed the same procedure for both and only the one failed.
Yes, I had read that connecting 'Run' with GND would force a hard reset, but unfortunately not in this case.
Weird. Not sure what it could be. Let's just replace it.
Send an email to [email protected] with a link to this post and they can send you a replacement Pico 2 RP2350.
- tcroswell
To be clear, I performed all those steps in the right order and it just doesn't work for some reason.
I can't see anything visibly wrong with it; it looks just like the other one. Don't get it.
The RP2350 has a ROM bootloader, which makes it pretty hard to brick. There might be a minor connection issue preventing it from going into bootloader mode (can't sense the bootsel pin state?). Or it could be power related (bad vreg?). Or something else.
- Franklin97355
Make sure you test it with only the USB connected to verify it is working properly. Let us know if there is a problem.tcroswell wrote:What do you suggest?
- tcroswell
I've tested it again today using only the USB. It is quite unresponsive.
- Franklin97355
Did you test the replacement Carter authorized in a post above?
