featherwing midi question
Microsoft's MakeCode platform for easy blocks-style programming
Post Reply
daddyben1
Post by daddyben1 »
is it possible to receive midi data like parse from the Music Maker FeatherWing using an esp32 ? I know the featherwing has a sd card reader attached and is capable to decode midi, i see lots of info on how to connect a cable from a midi controller and the featherwing will play it. but i want to receive real time midi from the sd card that's attached to the featherwing so i can use that data to run a motor... any ideas ?
dastels
Re: featherwing midi question
Post by dastels »
You want to read MIDI files from the SD card?
daddyben1
Post by daddyben1 »
yes in real time...like a parser..
dastels
Post by dastels »
Ok, got it!
Have a look at https://learn.adafruit.com/neotrellism4 ... ynthesizer. The code is written using CircuitPython, but shouldn't be too difficult to port to C++ if you need. All that would really need changing is the event methods (Ie. note_on, note_off) in the Synth class, and all the audio related code can be removed.
Post Reply
Return to “MakeCode”
