ESPTool on Chrome
- blakebr
ESPTool on Chrome
What is the setting in Chrome that must be changed/set to let ESPTool work to update AirLift?
Bruce
Bruce
- mikeysklar
Re: ESPTool on Chrome
I don't know if you still need to set these, but at one point:
chrome://flags
Experimental Web Platform features (enable)
Settings -> Privacy and Security -> Site Settings -> Additional permisions -> Serial Ports (check permissions)
Also make sure you have the pass-thru mode enabled for the Airlifts
chrome://flags
- blakebr
Mike,
Chrome may have changed things. When I follow the path you gave it looks like a bunch of sites are enabled. When I access the ESPTool web page, all I get is:
Using a logic probe I see:
CS = Low
RST = High with a pulse after I hit RESET on the Pico RP2040
GPIO0 = Low
RX = High with pulses every 4 seconds (Data?)
TX = High with pulses every 4 seconds
The lash-up had previously worked when I updated my AirLift to 1.7.7. I used it and set it aside and have not touched it. I have verified the wiring a dozen times.
I know I have the correct COM Port because I get the following when I hit RESET on the Pico:
On a different breadboard I setup the tool using a Feather RP2040, and I get the same results.
I am using these *.UF2 files:
And it just sits there.esptool.js
Serial port WebSerial VendorID 0x2e8a ProductID 0xa
Connecting...
CS = Low
GPIO0 = Low
Something has changed. I don't know what. I am still using Windows 10 with all updates. It may have been one of those updates. I am not using a USB hub.Error: Failed to execute 'setSignals' on 'SerialPort': Failed to set control signals.
BrucePico-RP2040-Passthru.UF2
Adafruit-Feather-RP2040-Passthru.UF2
- mikeysklar
Agreed. Adafruit_WebSerial ESPTool is not currently working with Airlifts. I tried a MatrixPotal M4 and PyPortal to confirm.
When I switch over to a straight ESP32-S2 Rev TFT it connects as expected.
I believe the issue started a week ago with a fairly routine esptool-js update. It might not be even related to that code. Last time it was a hard coded release version messing up the hard reset logic on the AirLifts.
I'll take a look.
I'll take a look.
- jerryn
FWIW — I ran into this today with a Matrixportal M4.
I was able to update it successfully by installing esptool.py and running it:
https://learn.adafruit.com/upgrading-es ... py-3124147
- mikeysklar
Thx @jerryn. The CLI esptool.py is a good work around for now.
- mikeysklar
Better summary of Adafruit_WebSerial_ESPTool release 1.3.1 last week.
fix : Passthrough logic inside hardReset() by @mikeysklar in #304
fix : jsdelivr updated to current release by @mikeysklar in #305
fix : version# --> @latest by @mikeysklar in #306
Bump @types/node from 22.9.0 to 22.9.3 by @dependabot in #309
Bump rollup from 4.25.0 to 4.27.4 by @dependabot in #308
Bump typescript from 5.6.3 to 5.7.2 by @dependabot in #310
Update to use esptool-js by @makermelissa in #311
Update GitHub Pages Actions by @makermelissa in #318
Point to esptool-js 0.5.3 by @makermelissa in #320
- mikeysklar
- blakebr
Mike,
Thank you.
The reason I am working on the update process is I am hoping to make a CircuitPython code.py that will do what the *.UF2 files do. This would then possibly make the upgrade workable on more than just two MCU boards. And possibly on the RP2350 boards. I have the UART I/O figured out. The USB I/O is being stubborn.
I needed a working *.UF2 process to test against.
Bruce
Thank you.
Bruce
- Timeline
Does the ESP tool work on RPi RP2040/2350 board in the first place (or the MatrixPanel M4 running a ATSAMD51J19 Cortex M4 processor)? It is after all, a serial flasher utility for Espressif chips which the RPi chips are not.
- mikeysklar
I believe it does as long as the chips are connected via SPI and *not reset* upon connection.
Keep in mind that boards like the PyPortal, MatrixPortal and Metro Airlift are M4 based with a ESP32 co-processor.
I looked into the code last night and see a plausible work around. There is a customizable reset option. A better permanent solution is a PR submission to Espressif that adds "no reset" support for the esptool-js utility.
- blakebr
The RP2040 ESPTool is for passthrough only it use 5 control lines CS. RST, GPIO0, RX and TX. SPI is not used for updates. SPI is used for WiFi. The core code for the RP2040 MCUs looks like:
Bruce
While True:
if USB Character: Send it out the UART port
if UART Character: Send it out the USB port
