Not sure if this is the right place to ask this.
I would like to not use the USB port for charging. Can I supply 5v positive to the pad marked '5v' and 5v negative to 'GND' pad next to the 'BAT' pad and use the 'GND' pad also as the negative to the battery along with the 'BAT' pad?
I would then not be using the USB for voltage/current in and wouldn't be using the output plug but would be using the breakout pads for that.
Thanks,
Sumner
Micro-Lipo Charger for LiPoly Batt with USB Type C Jack
- 1fatgmc
- adafruit_support_bill
Re: Micro-Lipo Charger for LiPoly Batt with USB Type C Jack
Yes. If you have a regulated 5v supply, you can power the board via the GND and 5v pins instead of via the USB connector.
- 1fatgmc
Thanks, so the one GND pad is a common ground for both sides of the circuit,
Sumner
Sumner
Yes. The GND is common to both the input and output sides.
- 1fatgmc
