'module' object has no attribute 'A14'
Post Reply
aschmie
Post by aschmie »
I'm trying to set up the softpot potentiometer to work on a teensy4.1.
I have gotten it to work on other analog pins, but for some reason I am getting
File "<stdin>", line 17, in <module>
AttributeError: 'module' object has no attribute 'A14'
for the following code:
potentiometer5 = AnalogIn(board.A1)  # potentiometer connected to A1, power & ground
potentiometer6 = AnalogIn(board.A16)  # potentiometer connected to A1, power & ground
It does this for A14, A15, and A16 and with nothing else plugged in.
Any help would be greatly appreciated!
dastels
Re: 'module' object has no attribute 'A14'
Post by dastels »
In the REPL execute the following and post the result.
import board
dir(board)
aschmie
Post by aschmie »
['__class__', '__name__', 'A0', 'A1', 'A10', 'A11', 'A12', 'A13', 'A2', 'A3', 'A4', 'A5', 'A6', 'A7', 'A8', 'A9', 'CLK', 'CMD', 'D0', 'D1', 'D10', 'D11', 'D12', 'D13', 'D14', 'D15', 'D16', 'D17', 'D18', 'D19', 'D2', 'D20', 'D21', 'D22', 'D23', 'D24', 'D25', 'D26', 'D27', 'D28', 'D29', 'D3', 'D30', 'D31', 'D32', 'D33', 'D34', 'D35', 'D36', 'D37', 'D38', 'D39', 'D4', 'D40', 'D41', 'D42', 'D43', 'D44', 'D45', 'D46', 'D47', 'D48', 'D49', 'D5', 'D50', 'D51', 'D52', 'D53', 'D54', 'D6', 'D7', 'D8', 'D9', 'DAT0', 'DAT1', 'DAT2', 'DAT3', 'FLASH_CS', 'I2C', 'LED', 'MISO', 'MOSI', 'PSRAM_CS', 'QSPI_CLK', 'QSPI_IO0', 'QSPI_IO1', 'QSPI_IO2', 'QSPI_IO3', 'RX', 'RX1', 'RX2', 'RX3', 'RX4', 'RX5', 'RX6', 'RX7', 'RX8', 'SCK', 'SCL', 'SCL0', 'SCL1', 'SCL2', 'SDA', 'SDA0', 'SDA1', 'SDA2', 'SPI', 'TX', 'TX1', 'TX2', 'TX3', 'TX4', 'TX5', 'TX6', 'TX7', 'TX8', 'UART', 'USB_HOST_DM', 'USB_HOST_DP', 'USB_HOST_POWER', '__dict__', 'board_id']
aschmie
Post by aschmie »
Also going to post the Teensy 4.1 pinout in case it is useful
https://www.pjrc.com/teensy/pinout.html
dastels
Post by dastels »
Well, there's no board.A14.
Try board.D38. Comparing the schematic (https://www.pjrc.com/teensy/schematic.html) and pin definitions (https://github.com/adafruit/circuitpyth ... y41/pins.c), that looks like it's it.
aschmie
Post by aschmie »
Yup that looks like it is working! Thanks!
Timeline
Post by Timeline »
Someone (who cares; I have no interest in this board) should submit a change to the pin definitions to add not only the A14 but A14 through A17.
Post Reply
Return to “Microcontrollers”
