Glue for conductive rubber?
Wearable electronics: boards, conductive materials, and projects from Adafruit!
Post Reply
KazimirO
Post by KazimirO »
Anyone found a way to stick conductive rubber parts together? Or maybe you know what type of rubber it is? Butyl, nitrile, latex?
adafruit_support_mike
Re: Glue for conductive rubber?
KazimirO wrote: Thu Jan 09, 2025 11:31 pm Anyone found a way to stick conductive rubber parts together?
Have you tried E6000? It works on silicones, which are notoriously hard to glue.
KazimirO wrote: Thu Jan 09, 2025 11:31 pm Or maybe you know what type of rubber it is? Butyl, nitrile, latex?
Latex is unlikely, but if there's an elastomer there's probably a conductive version of it somewhere.
In terms of basic price, I'd expect polyurethanes to be the most common. Your best bet will be to look for a datasheet on the specific product you're using though.
KazimirO
Post by KazimirO »
Sorry, this is the product: https://www.adafruit.com/product/5464
It doesn't seem to have a datasheet.
I've tried silicone, and normal tire cement doesn't work. Maybe it's EPDM? Nitrile?
Got it.. I'll see if our products team has any more information.
T_Mo
Post by T_Mo »
You're probably needing a conductive adhesive?
KazimirO
Post by KazimirO »
Oddly enough, the adhesive does not need to be conductive for my use case. Insulating it is more the issue.
KazimirO
Post by KazimirO »
Just FYI, E6000 does not work at all, but RTV silicone sealant seems to work OK.
Maybe it *is* silicone rubber?
We haven't gotten any response from the vendor yet, so thanks for the follow-up!
Post Reply
Return to “Wearables”
