HX711
DrakeBB
Re: HX711
Post by DrakeBB »
I'm also getting measurable readings from the voltmeter on the strain gage load cell as well
DrakeBB
Re: HX711
Post by DrakeBB »
DrakeBB
Re: HX711
Post by DrakeBB »
DrakeBB
Re: HX711
Post by DrakeBB »
The voltmeter is saying the same thing on the CPG as the hx711:
Vin to GND: 3V
Vin to DATA(D7): 3V
Vin to SCK(D8): 0
DrakeBB
Re: HX711
Post by DrakeBB »
Here are some pictures showing the connections on the hx711. A little blurry but shows what I was testing. I can send pictures of the voltmeter on the strain gage load cell if that's needed as well
DrakeBB
Re: HX711
Post by DrakeBB »
Here's some more picture of the strain gage load cell connection to the hx711
mikeysklar
Re: HX711
Post by mikeysklar »
Good work confirming the wiring. Also seeing some voltage readings on from the sensor.
I think this is going to come down to CircuitPython being finicky about pin names.
Instead of using D8 (SCK) and D7 (DATA) try the other names. Do not move the wires.
D8 can also be RX or A6
D7 can also be TX or A7
DrakeBB
Re: HX711
Post by DrakeBB »
I tried both. The readings I got didn't respond to strain in the bar though
HX711 E.PNG (89.48 KiB) Viewed 115 times
HX711 D.PNG (87.26 KiB) Viewed 115 times
mikeysklar
Re: HX711
Thx for trying. The values being maxed out might be a
Which model are you using for the strain gauge load cell?
I'll order some parts and try to reproduce / resolve.
In the meantime are you comfortable trying with Arduino code? The behavior may change and it would help to know if this is CircuitPython specific.
DrakeBB
Re: HX711
Post by DrakeBB »
I'm using the 20kg load cell adafruit#4543
I'm willing to try anything. I've never used Arduino code before though.
mikeysklar
Re: HX711
I ordered some parts, but won't have them until mid next week.
The guide will walk you through Arduino setup and the example code is provided. If it is too much hassle don't sweat it. I'll be able to play along soon. I ordered a few different gauges to compare with as well.
DrakeBB
Re: HX711
Post by DrakeBB »
First time ever using Arduino. I think I did everything right. You'll have to let me know though.
T_Mo
Re: HX711
Post by T_Mo »
If you have pushed the pins of the 0.1 inch header into the holes on the prototype breadboard, and you are connecting to it via jumpers with smaller diameter pins, you may be having unreliable connections between the controller board and the strain gauge breakout.
The contact rows on a protoboard do not much like having different sized wires connected to the same row of holes.
mikeysklar
Re: HX711
@DrakeBB - T_Mo brings up a good point about wiring. Although it did seem like you were getting readings off the terminal block that had reasonable voltage.
When you open the Arduino Serial Monitor what do you see?
DrakeBB
Re: HX711
Post by DrakeBB »
Here is what the serial monitor is showing.
Would using a microcontroller with headers be a possible solution to this?
arduino a.PNG (62.19 KiB) Viewed 89 times
Post Reply
