Halloween display this morning 31 October 2024
Post Reply
Azzura
Post by Azzura »
Hi Ada fans. Happy Halloween 🦇 Made an LED Matrix Display (128 x 64) some time ago for fun and set it up for a Halloween window event. Enjoy 🎃
LED matrix display.jpg (226.59 KiB) Viewed 792 times
Halloween image on led matrix display.jpg (189.51 KiB) Viewed 792 times
johnpark
Re: Halloween display this morning 31 October 2024
Post by johnpark »
This looks great! Can you give some details on the enclosure and build?
Azzura
Post by Azzura »
Hi John,
I do apologise for my slow response, I have been on an amazing South East Asia journey and I am now in Canada sliding down snowy ☃ slopes, I have only today logged in and seen your post 😔.
The box is made up of two PVC junction boxes painted black. Inside is an Interstate75 board connected to two 64x64 HUB75 LED displays config 128x64. I will install the IR proximity sensor soon so that the display activates when something passes by. (It made the cat jump ... ☺)
I set this up to run a Slideshow, coded as per "Creating Slideshows in CircuitPython by Anne Barela", worked super good ☺.
However, when I moved from the slideshow to "Code the Sprite Sheet Animation Display" by yours truly, I ran into an error I have not seen before. The code lines (I am presuming) which appear to be the area of interest.
# --- Display setup ---
matrix = Matrix(bit_depth=4)
sprite_group = displayio.Group()
matrix.display.root_group = sprite_group
The "display" attribute has me confused.
I have added some images for clarity, trust they help. I ported the RGBMatrix config I used in the slideshow over to the sprite code and incurred this error. I would truly appreciate your advise.
Again, apologies for the late reply.
CURRENT STATUS.
CP version 9.2.1
I have updated all of the library folders and files listed in the sprite project library with the latest CP library folders/files accordingly.
Background History:
SLIDESHOW:
MATRIX = rgbmatrix.RGBMatrix(
width=64,
height=32,
bit_depth=4, tile=1, serpentine=False,
rgb_pins=[board.R0, board.G0, board.B0, board.R1, board.G1, board.B1],
addr_pins=[board.ROW_A, board.ROW_B, board.ROW_C, board.ROW_D],
clock_pin=board.CLK,
latch_pin=board.LAT,
output_enable_pin=board.OE,
DISPLAY = framebufferio.FramebufferDisplay(MATRIX, auto_refresh=False, rotation=0)
slideshow = SlideShow(DISPLAY,
folder="/images",
loop=True,
order=PlayBackOrder.ALPHABETICAL,
dwell=1.0)
while slideshow.update():
pass
SPRITE SHEET ANIMATION: not working due to attribute error
matrix = rgbmatrix.RGBMatrix(
width=64,
height=32,
display = framebufferio.FramebufferDisplay(matrix, auto_refresh=False, rotation=0)
Current CP 9.2.1.jpg (188.11 KiB) Viewed 55 times
Slideshow code works great same RGBMatrix format.jpg (287.76 KiB) Viewed 55 times
RGBMatrix has no attribute display.jpg (482.51 KiB) Viewed 55 times
Azzura
Post by Azzura »
Hi John,
I gave up trying to solve the attribute error on the sprite code, fortunately I had a matrix portal and decided to bypass the unknown attribute headache.
Worked well with the portal code, so I made a "welcome back" scrolling sign for my friend and added an animation sprite about 3 seconds long of a jumping kangaroo waving its paw and displaying "G'Day". Unfortunately video files are not accepted on this site.
Here is a photo of the display showing a still image of the scroller and a single frame of the animation on the 128x64 LED matrix panel.
Regards
Welcome back with jumping Kangaroo.jpg (91.73 KiB) Viewed 38 times
Post Reply
Return to “AdaBox! Show us what you made!”
