Hello, I bough the sim kit reader from yall and need some help troubleshooting. Here are my errors when i open and run psysimreader application:
File "pySimReader.py", line 267, in buttonConnectReader
File "pySIMserial.pyc", line 111, in connectReader
File "pySIMserial.pyc", line 143, in openSession
File "serial\serialutil.pyc", line 166, in __init__
File "serial\serialwin32.pyc", line 49, in open
serial.serialutil.SerialException: could not open port COM1: (5, 'CreateFile', 'Access is denied.')
Also....how do I know which port to choose?
Thanks for any help in advance.
Help with Sim Reader
Re: Help with Sim Reader
how are you connecting to it
With the port to USB cable I bought from adafruit
What serial port is being assigned to your USB/Serial cable? You need to find that and select that port in the PySim software.
I am using windows 7 and under devices in the control panel I have a USB serial Controller in the unspecified section. It complains that the USB-Serial doesnt have a driver. When I go to properties of USB/Serial controller is says port_#0001.Hub_#0003
When I select com1 to connect to i get the error message :
File "pySIMserial.pyc", line 160, in openSession
TypeError: ord() expected a character, but string of length 0 found
And when i select any other com i get the error message:
serial.serialutil.SerialException: could not open port COM3: (2, 'CreateFile', 'The system cannot find the file specified.')
You won't be able to talk to it without a driver. The product page has a link to the manufacturer's site for the latest drivers:
http://www.adafruit.com/index.php?main_ ... ucts_id=18
I have the drivers intalled, the device now reads as prolific USB-to-serial Comm Port(COM3).
However, when I run the software and select com 3 and try and connect the reader i still get the error message:
What does this mean?
+1adafruit wrote:did you read http://ladyada.net/make/simreader/faq.html ?
I had the same problem on all my sample SIMs. I followed your FAQ (including touching up the solder) to no avail. With a SIM installed, I ended up just pinching in the SIM tray really hard in the center and it works now. No matter how I try to move the SIM tray, I can't re-emulate the error. Perhaps the SIM tray's contacts were coated in something from the factory, inhibiting contact. Try cleaning the contacts....
Hi, I get the below error when I connect my kit to any of the com ports. I have tried solder touch-up, slightly pressing the sim card in the holder to make sure its has gud contact ... but no success.
File "pySimReader.py", line 30, in <module>
File "zipextimporter.pyc", line 82, in load_module
File "wx\__init__.pyc", line 45, in <module>
File "wx\_core.pyc", line 4, in <module>
File "zipextimporter.pyc", line 98, in load_module
ImportError: MemoryLoadLibrary failed loading wx\_core_.pyd
