Linking Four SHift Register
bob500000
Post by bob500000 »
Hi Guys,
Is it possible to link 4 shift registers via one arduino board, I am either looking at using just 4 pins on the board, I have all the code that I want to run, just the linking of the shift registers.
I was intially thinking about doing the following:
//First Shift Register
Clock1 int 1;
Data1 int 2;
OutputEnable1 int 3;
Latch1 int 4;
//Second Shift Register
Clock2 int 5;
Data2 int 6;
OutputEnable2 int 7;
Latch2 int 8;
//Third Shift Register
Clock3 int 9;
Data3 int 10;
OutputEnable3 int 11;
Latch3 int 12;
//Fourth Shift Register
Clock4 int 13;
\\Analog Pins
Data4 int14;
OutputEnable4 int 15;
Latch4 int 16;
However this uses 16 ports on the board, I currently use 3 ports already which drive 1 set of LED's and 2 switches.
is there a simplier solution?
Cheers.
adafruit_support_mike
Re: Linking Four SHift Register
When you say 'shift registers', do you mean the 74HC595?
If so, you're in luck. The '595 is designed to be daisy-chained. There's a pin named 'Q7S' which connects to the last bit in the chip's internal shift register, and all you need to do is connect that to the 'DS' (serial data input) pin of the next chip.
Daisy-chained '595s all use the same serial-data and display-output signals, so you can run a whole string of them from the same pins you'd need to run a single one.
bob500000
Post by bob500000 »
Thanks mike, I am talking about the 74HC595.
So the code I have will work?
In terms of power, will I need additional support, I am currently running 3 boards on a 12v power supply and am wondering if this is going to suffice running 4 shift registers.
Cheers
As written, no it won't. In C, you need to put the type declaration (int) before the name of the variable (Clock, etc). Also, you only need the pin assignments for a single chip.
Here's a rough version of what the code should look like:
/*  The original code for your first shift register
    'const' tells the compiler these values should never change
    'char' tells the compiler to use 8-bit slots to store the values
const char Clock = 1;
const char Data = 2;
const char OutputEnable = 3;
const char Latch = 4;
/*  A new variable to count the number of chips in the chain
const char registerCount = 4;
digitalWrite( Latch, LOW );     //  get ready to shift data
/*  I've written this code to count backwards, because the first
    bit you send as data will end up going farthest.  This arrangement
    puts chip-1, bit-1 closest to the Arduino and chip-4, bit-8
    farthest away.
for (char i=registerCount ; i ; i--) {
    for (char j=8 ; j ; j--) {
        digitalWrite( Clock, LOW );
        digitalWrite( Data, chipAndBit( i, j ) );
        digitalWrite( Clock, HIGH );
digitalWrite( Latch, HIGH );    //  shift everything to output
/*  This routine decides what value each chip/bit should have
char chipAndBit (char c, char b) {
    if (random() > .5) {
        return( HIGH );
    } else {
        return( LOW );
Now, that's written the long way to give you a better idea of what's going on. You can eliminate the two loops that send data and manage the clock by using the Arduino library's shiftOut() method. There's a page dedicated to driving a '595 with shiftOut here: http://arduino.cc/en/Tutorial/ShiftOut
bob500000
Post by bob500000 »
Thanks mate,
Looking at your code was dreading how you put it together.
Link to image forum, sorry will not let me up upload currently.
http://forums.adafruit.com/viewtopic.php?f=25&t=38620
I currently have the following code and am wondering if you could take a look at it, I had 4 shift registers daisy chained together and need it to do the following:
When the user presses button 0 once the first sequence is carried out
when the user presses button 0 twice the second sequence is carried out
When the user presses button 1 the second sequence is carried out
when the user presses button 1 twice the first sequence is carried out
when the first set of LED's are lit, meaning both tubes they need to turn off to allow the second lot to follow suit lighting the same colours as the first tubes, as bit confusing I know but to help I uploaded a picture to show the project.
Anyway once they have lit up they need to light the final set which will be based upon pin 10. to complete the cycle.
#include <Button.h>
int latchPin = 5;
int clockPin = 6;
int dataPin = 4;
int outputEnablePin = 3;
int ledPin = 10;
//Button trigger = Button(2,LOW);
int sr1Colour = 0;  // Set for ShiftReg1 as 0 = off, 1 = green, 2 = red
int sr2Colour = 0;
byte leds = 0;
byte button[] = {8, 9};
byte switch_value = 0;
boolean btnOn = false;
int count = 0;
#define NUMBUTTONS sizeof(button)
byte pressed[NUMBUTTONS], justpressed[NUMBUTTONS], justreleased[NUMBUTTONS];
  setBrightness(0);
  pinMode(latchPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(outputEnablePin, OUTPUT);
  //pinMode(2,INPUT); //Trigger switch sits on pin 2
  Serial.begin(9600);
  Serial.println("Welcome");
  byte i;
   for (i=0; i< NUMBUTTONS; i++) {
    pinMode(button[i], INPUT);
    digitalWrite(button[i], HIGH);
    //Timer2 Overflow Interrupt Enable
  TIMSK2 |= 1<<TOIE2;
//byte pressCount1 = 0;
SIGNAL(TIMER2_OVF_vect) {
  check_switches();
void check_switches()
  static byte previousstate[NUMBUTTONS];
  static byte currentstate[NUMBUTTONS];
  byte index;
  for (index = 0; index < NUMBUTTONS; index++) {
    currentstate[index] = digitalRead(button[index]);   // read the button
    Serial.print(index, DEC);
    Serial.print(": cstate=");
    Serial.print(currentstate[index], DEC);
    Serial.print(", pstate=");
    Serial.print(previousstate[index], DEC);
    Serial.print(", press=");
    if (currentstate[index] == previousstate[index]) {
      if ((pressed[index] == LOW) && (currentstate[index] == LOW)) {
          // just pressed
          justpressed[index] = 1;
          count = count+1;
          //switch_value = switch_value + 1;
      else if ((pressed[index] == HIGH) && (currentstate[index] == HIGH)) {
          // just released
          justreleased[index] = 1;
      pressed[index] = !currentstate[index];  // remember, digital HIGH means NOT pressed
    //Serial.println(pressed[index], DEC);
    previousstate[index] = currentstate[index];   // keep a running tally of the buttons
 //This is Button 1 Set Press
  if(justpressed[0] && btnOn)
    count;
    sequence2();
    justpressed[0] = 0;
    btnOn = false;
  if(justpressed[0]) {
    Serial.println("Button 0 pressed");
    btnOn = true;
    count;
    justpressed[0] = 0;
    sequence1();
// //This is Button 2 Set Press
if(justpressed[1] && btnOn)
    count;
    sequence1();
    justpressed[1] = 0;
    btnOn = false;
  if(justpressed[1]) {
    Serial.println("Button 1 pressed");
    btnOn = true;
    count;
    justpressed[1] = 0;
    sequence2();
// //Run final Sequence1
if (sr1Colour ==1 && sr2Colour==1){
  sequenceFinal1();
  ledPin = HIGH;
// //Run final Sequence2
if (sr1Colour ==1 && sr2Colour==2){
  sequenceFinal2();
  ledPin = HIGH;
// //Run final Sequence3
  sequenceFinal3();
  ledPin = HIGH;
// //Run final Sequence4
  sequenceFinal4();
  ledPin = HIGH;
 //This is updateShiftRegister
void updateShiftRegister()
   digitalWrite(latchPin, LOW);
   shiftOut(dataPin, clockPin, LSBFIRST, leds);// Change the start LED to 1
   digitalWrite(latchPin, HIGH);
 //This is updateShiftRegister2
void updateShiftRegister2()
   shiftOut(dataPin, clockPin, MSBFIRST, leds);// Change the start LED to 8
 //This is updateShiftRegister3
void updateShiftRegister3()
 //This is updateShiftRegister4
void updateShiftRegister4()
 //This is updateShiftRegister5
void updateShiftRegister5()
   shiftOut(dataPin, clockPin, LSBFIRST, leds);// Change the start LED to 8
 //This is updateShiftRegister6
void updateShiftRegister6()
 //This is updateShiftRegister7
void updateShiftRegister7()
 //This is updateShiftRegister8
void updateShiftRegister8()
 //This is setBrightness
void setBrightness(byte brightness) // 0 to 255
  analogWrite(outputEnablePin, 255-brightness);
 //This is Sequence 1
void sequence1(){
  Serial.println("button 1");
  for (int i = 0; i < 4; i++)
    bitSet(leds, i);
    updateShiftRegister();
    delay(50);
    for (byte b = 0; b < 255; b++)
      setBrightness(b);
      delay(20);
    Serial.println(count);
    if(count>=3){
     Serial.println("Count =");
      Serial.print(count);
      leds = 0;
      //for (int i = 0; i < 4; i++)
    bitSet(leds, -5);
    delay(50);
      setBrightness(255);
      count = 0;
      break;
    if (justpressed[0] && btnOn && (count >=3)) {
      Serial.println("Button 0 pressed again");
      count;
      leds = 0;
      setBrightness(255);
      break;
  //bitSet(leds,0);
  //delay(1000);
   sr1Colour = 1; //Set SR1 to green
 leds = 0;
   //switch_value = 0;
  setBrightness(255);
 //This is Sequence 2
void sequence2(){
  Serial.println("button 2");
    bitSet(leds, i);
    updateShiftRegister2();
    delay(50);
      setBrightness(b);
      delay(20);
    if(count>=3)
      leds = 0;
    bitSet(leds, -5);
    delay(50);
      setBrightness(255);
      count = 0;
      break;
    if (justpressed[1] && btnOn && (count >=3)) {
      leds = 0;
      break;
  //bitSet(leds,0);
  //delay(1000);
   sr1Colour = 2; //Set SR1 to red
  leds = 0;
   //switch_value = 0;
  setBrightness(255);
 //This is Sequence 3
void sequence3(){
    bitSet(leds, i);
    updateShiftRegister3();
    delay(50);
      setBrightness(b);
      delay(20);
    if(count>=3){
      leds = 0;
    bitSet(leds, -5);
    delay(50);
      setBrightness(255);
      count = 0;
      break;
      count;
      leds = 0;
      setBrightness(255);
      break;
  //bitSet(leds,0);
  //delay(1000);
 leds = 0;
   //switch_value = 0;
  setBrightness(255);
 //This is Sequence 4
void sequence4(){
    bitSet(leds, i);
    delay(50);
      setBrightness(b);
      delay(20);
    if(count>=3){
      leds = 0;
    bitSet(leds, -5);
    updateShiftRegister4();
    delay(50);
      setBrightness(255);
      count = 0;
      break;
      count;
      leds = 0;
      setBrightness(255);
      break;
  //bitSet(leds,0);
  //delay(1000);
  sr1Colour = 1; //Set SR1 to Green
 leds = 0;
   //switch_value = 0;
  setBrightness(255);
 //This is Sequence 5
void sequence5(){
    bitSet(leds, i);
    updateShiftRegister5();
    delay(50);
      setBrightness(b);
      delay(20);
    if(count>=3){
      leds = 0;
    bitSet(leds, -5);
    delay(50);
      setBrightness(255);
      count = 0;
      break;
      count;
      leds = 0;
      setBrightness(255);
      break;
  //bitSet(leds,0);
  //delay(1000);
 leds = 0;
   //switch_value = 0;
  setBrightness(255);
 //This is Sequence 6
void sequence6(){
    bitSet(leds, i);
    updateShiftRegister6();
    delay(50);
      setBrightness(b);
      delay(20);
    if(count>=3){
      leds = 0;
    bitSet(leds, -5);
    delay(50);
      setBrightness(255);
      count = 0;
      break;
      count;
      leds = 0;
      setBrightness(255);
      break;
  //bitSet(leds,0);
  //delay(1000);
 leds = 0;
   //switch_value = 0;
  setBrightness(255);
 //This is Sequence 7
void sequence7(){
    bitSet(leds, i);
    updateShiftRegister7();
    delay(50);
      setBrightness(b);
      delay(20);
    if(count>=3){
      leds = 0;
    bitSet(leds, -5);
    delay(50);
      setBrightness(255);
      count = 0;
      break;
      count;
      leds = 0;
      setBrightness(255);
      break;
  //bitSet(leds,0);
  //delay(1000);
 leds = 0;
   //switch_value = 0;
  setBrightness(255);
 //This is Sequence 8
void sequence8(){
    bitSet(leds, i);
    updateShiftRegister8();
    delay(50);
      setBrightness(b);
      delay(20);
    if(count>=3){
      leds = 0;
    bitSet(leds, -5);
    delay(50);
      setBrightness(255);
      count = 0;
      break;
      count;
      leds = 0;
      setBrightness(255);
      break;
  //bitSet(leds,0);
  //delay(1000);
 leds = 0;
   //switch_value = 0;
  setBrightness(255);
 //This is Final Sequence 1
 void sequenceFinal1(){
   sequence5();
   sequence7();
 //This is Final Sequence 2
void sequenceFinal2(){
   sequence5();
   sequence8();
 //This is Final Sequence 3
void sequenceFinal3(){
   sequence6();
   sequence7();
 //This is Final Sequence 4
void sequenceFinal4(){
   sequence6();
   sequence8();
cheers.
Looks okay overall, but there are a few things to tweak:
This line isn't quite correct:
It works for this specific piece of code because you've defined the array 'button' to contain bytes, and sizeof() returns the number of bytes in a data structure. It's much safer to write that kind of thing like this though:
#define NUMBUTTONS sizeof(button) / sizeof(button[0])
That divides the total size of the array by the size of a single cell, giving you the number of items in the array.
This bit of the setup() function:
Contradicts itself.. it doesn't make sense to write to a pin that's configured for INPUT. You can lose the digitalWrite() line.
In these sections:
    count;
    sequence2();
    justpressed[0] = 0;
    btnOn = false;
the line containing 'count;' doesn't do anything. It isn't really wrong, and the compiler will probably throw that statement away, but the code will be easier to read if you remove all the lines like that.
This chunk probably won't do what you want:
    bitSet(leds, -5);
    delay(50);
      setBrightness(255);
You've commented out the loop, but the block containing the code will still execute once.. and I have no idea what 'bitSet(leds, -5)' will do. From what I can see in the Arduino reference, the second argument needs to be a positive integer.
If I were writing code to do the same thing I'd probably arrange it differently, but that's a question of personal style and not a question of function. If the code runs, does what you want it to, and you can understand what's going on if you leave it alone for six weeks and read it again, you're good.
bob500000
Post by bob500000 »
Hi Mike thanks for the advice,
Curently almost all of it works, the buttons function proactively, sometimes they work sometimes they dont having a problem getting my head around the button code so e-engineered some previous code.
the count; was fo test puposes, doesnt really do anything useful apart from tell me how many times the buttons have pressed and then eset if its more than 3 to turn all the LED's off.
basically the LED code is to fade each LED on individually, when it has ran though the shift register.
bitSet(leds, -5); - This turns the LED's off once the next sequence starts, if you was to write it out, can you show me how you would do it.
cheers
coolr
Post by coolr »
Can I get the status to tell which LED is on??
bob500000
Post by bob500000 »
Your going to need to write a flag and then do an if statement to show if it is true.
The way I did it, was to create to variables sr1colour and sr2colour, these both =0 but when a set of LED's was lit then the at the end of the sequence the sr1colour or sr2colour values were changed depending whcih side of the shift register ran.
For example
if the first shift register ran the first 4 bits then this would be sr1colour as the first 4 were attached to green LED'S
if the firt shift register ran the last 4 bits then this would be sr2colour, as the last 4 were attached to red LED's
So in therory you could use the following code to show each time an LED is lit
heres a break down of what the code actually does:
void sequence1(){
    bitSet(leds, i);
    delay(50);
      setBrightness(b);
      delay(20);
This first bit of code cycles through the first 4 bits on the shift register, lighting each one individually, the updateshift register is the cycle moving forward fading on the LED's one at a time,
    if(count>=3){
      leds = 0;
    bitSet(leds, -5);
    delay(50);
      setBrightness(255);
      count = 0;
      break;
This bit carries on from the first but checks to see if the button has been pressed >= 3 times, if it has then the sequence will stop and the LED's will turn off, thus reseting the program.
Hope this helps.
bob500000 wrote:bitSet(leds, -5); - This turns the LED's off once the next sequence starts, if you was to write it out, can you show me how you would do it.
Assuming a bit value of 0 means "turn the LED off", I'd just say:
leds = 0;
I generally handle bitmasks with the bitwise logic functions or by setting the values directly:
//  set every other bit in the byte:
leds = B10101010;
//  shift the bits left and add another 1 at the end:
leds <<= 1;
leds += B00000001;
That last line could be written more simply (leds++), but writing it in that form tells the reader I'm playing with the bit patterns.
bob500000
Post by bob500000 »
Hi mike,
I understand that although, first off the LEDs don't turn off when you put them at 0, have to use a value that is less than 0; not too sure why this is,
Looking at the cycle I am only using some of the register and it needs to switch been the lsb and the msb to light the right colour.
Example being that the lsb will light 3 LEDs in green and on the same register the msb lights 3 LEDs in red. So the cycle proposed is more complex than just defining which side of the register is lit and setting the amount of LEDs lit!
Can you confirm that the rest of the code will do what I require it to especially the final sequence parts
Cheers
bob500000
Post by bob500000 »
Hi mike any ideas on the above,
Not to rush but got a deadline for next week!
Cheers
If the compiler likes your syntax I don't see any other problems. The best test is to compile it, load it, and let it run.
Are you running into problems with some specific part of the code or feature?
bob500000
Post by bob500000 »
Yeah all works fine apart from the last bit is where I need it to look at the sr1colour and the sr2colour and then works out if the values true or false and if so which method to call depending on the if statements detailed in final, I can make it get so far but then it decides to light all the LEDs on the third and fourth shift registers really confused why that would be unless I need to start from the last and move to the first!
If you're talking about this section:
  sequenceFinal1();
  ledPin = HIGH;
  sequenceFinal2();
  ledPin = HIGH;
  sequenceFinal3();
  ledPin = HIGH;
  sequenceFinal4();
  ledPin = HIGH;
It looks like you have a copy/paste error. The test that triggers sequenceFinal3() is the same as the one that triggers sequenceFinal1(). Same for sequenceFinal2() and sequenceFinal4():
//    these test for sr1Colour == 1 and sr2Coulour == 1
  sequenceFinal1();
  ledPin = HIGH;
  sequenceFinal3();
  ledPin = HIGH;
//    these test for sr1Colour == 1 and sr2Coulour == 2
  sequenceFinal2();
  ledPin = HIGH;
  sequenceFinal4();
  ledPin = HIGH;
Return to “Arduino”
