MidiSense Board Not recognised by midisense software
Posts about MIDIsense. open source MIDI sensor platform
humanpyramid
Post by humanpyramid »
Dear Ladyada,
I recently ordered two boards - an ADIO and the Sensor board. The ADIO works a treat and i've just set up an infrared sensor (one with a wider range up to 120cm) and i'm over the moon with it - ansolutley amazing/!!!!! But! the Sensor board for resistive sensors won't work...
The green power light comes on. The red/green led flashes green - it's sending midi. My UM EX 1 edirol midi to usb converter flashes to say it recieving midi. The audio setup on my mac book pro sends a test signal to say midi is being sent and received. But, the midisense software (which works great with the ADIO board states that it has failed to find any midisense boards when i try to connect to the sensor board. I've checked all my solder points - no cold joints etc. What could the problem be? Hope you can help. Ben
Post by adafruit »
hmm, i will check this out. odd that the adio board works but not the resistive one :(
humanpyramid
MIDISense Board Not recognised - Part 2
Strange isn't it that one works (ADIO) and one doesn't....
Could it be the R3 and R6 resistors? I found the build instructions for these are a little bit confusing.... Here's the resistors i thought the instructions were telling me to use:
R3 220 ohm
R6 220 ohm
R7 10k ( the instructions don't seem to say which one to use - i used the one i had left...)
R13 220 ohm
If these are wrong it should work if i put the right ones in!
Thanks for your help with this,
Benjamin Freeth
humanpyramid
Wrong Value Resistors Used
Can you clarify which resistors should be used in the following positions:
R3, R6, R7, R13?
Thanks,
B
michu
Re: Wrong Value Resistors Used
Post by michu »
humanpyramid wrote:Can you clarify which resistors should be used in the following positions:
R3, R6, R7, R13?
Thanks,
B
same error here! my debug log shows the same error as in this thread: http://forums.ladyada.net/viewtopic.php?t=5116, but the oszi is right, 16Mhz.
R13=1k
R10=10k
this information is from the build instruction side. Also noted there:
>Note: there was a PCB error in some very early MIDIsense resistive
>boards, R3 and R6 may be swapped! Check that the 220 ohm resistor
>connects to the MIDI jack and the ~1.5K resistor connects to the bi-color
>LED.
What early boards? I just mounted as instructed (i did not switch r3 and r6)
R3=220Ohm
I also noticed, R3 and R6 are swapped in those 2 pics!
michu
Post by michu »
ok i swapped R3 and R6 - still the same error. I looks like midisense dont receieve data (red blink), even if th midi controller sends data, according to its led. Ill guess i will have a look tomorrow with my voltmeter...
some quick information:
-usb drivers are ok, tested with midiox
-midi cables are not reversed
-soldering should be fine, as i double checked it
-green led is blinking, red led is only blinking when using midiox
michu
Post by michu »
Ok i read the instructions again:
Check that the 220 ohm resistor connects to the MIDI jack and the ~1.5K
resistor connects to the bi-color LED.
so - in other words
red-red-brown 220Ohm - connect to midi jack - r3
brown-black-red 1kOhm - connect to bi-color led - r6 connects to led
so i switched back the resistors...
then
-Make sure the amtel sits tight on the socket (mine wasn't really tight)
-i set dip-switch 1 and 2 to on
-there are no drivers from the manufactor (midi sonic 2x2, infrasonic)
Using Win XP SP2, I could connect to the device! I was unable to connect using Windows Vista SP1 (I also tried to "runas administrator")!
There were some errors in the connection:
00000043	19.19594955	[6476] 22:48:09: adding checkboxes
00000044	19.19656754	[6476] 22:48:09: adding names
00000045	19.21066666	[6476] 22:48:09: adding typechoice
00000046	19.25665092	[6476] 22:48:09: adding new panel: 13
00000047	19.37583733	[6476] 22:48:09: MIDI error: PortMidi: 'Buffer overflow'
00000048	20.18521881	[6476] 22:48:10: Done
00000049	20.18528557	[6476] 22:48:10: Found 1 boards
00000050	20.18531990	[6476] 22:48:10: Configuring board #13
00000051	20.21488380	[6476] 22:48:10: Sending Packet: 0xf0 0x7d 0x20 0xd 0x0 0xf7
00000052	21.23618507	[6476] 22:48:11: Sending Packet: 0xf0 0x7d 0x20 0xd 0x0 0xf7
00000053	21.66623878	[6476] 22:48:11: ***************Recv'd bad checksum: 16 sum = 86
00000054	21.66629791	[6476] 22:48:11: Recv'd Sysex: 0xf0 0x69 0x21 0xd 0x3f 0x10 0xf7
00000055	21.66631126	[6476] 22:48:11: enabling sensors 0x3f
00000056	21.67483521	[6476] 22:48:11: stop
00000057	21.67488861	[6476] 22:48:11: Started Listening
00000058	21.67504120	[6476] 22:48:11: Sensor 0
00000059	21.68149757	[6476] 22:48:11: Sending Packet: 0xf0 0x7d 0x32 0xd 0x0 0x0 0xf7
00000060	22.01914406	[6476] 22:48:12: Sending Packet: 0xf0 0x7d 0x10 0xd 0x1 0x0 0xf7
00000061	22.44915390	[6476] 22:48:12: MIDI error: PortMidi: 'Buffer overflow'
00000062	23.35701180	[6476] 22:48:13: Sending Packet: 0xf0 0x7d 0x10 0xd 0x1 0x0 0xf7
I started to verify the firmware... and canceled this procedure... NOW my midisense board act's "funny", when i power it on, the led flashes once red (guess this means that the bootloader should be fine), but the led does not flash green anymore! I guess when the bootloader works, it should be possible to upload a new firmware... or not?
michu
Post by michu »
OK it looks like I was right about updating the firmware...
But after erasing the eeprom, midisense crashed:
[7016] 23:24:28: Sending Packet: 0xf0 0x7d 0x44 0x1b 0xf7
[7016] 23:24:28: sent
[7016] 23:24:28: bootloader, skip checksum
[7016] 23:24:28: Recv'd Sysex: 0xf0 0x7d 0x33 0x9f
[7016] 23:24:28: Got reply, 0 bytes
[7016] 23:24:30: timeout
[7016] 23:24:30: Sending Packet: 0xf0 0x7d 0x44 0x1b 0xf7
[7016] 23:24:30: sent
[7016] 23:24:30: bootloader, skip checksum
[7016] 23:24:30: Recv'd Sysex: 0xf0 0x7d 0x33 0x9f
[7016] 23:24:30: Got reply, 0 bytes
[7016] 23:24:30: look for reply
[7016] 23:24:30: eek!
ARGH.. any hints?
EDIT:
after erasing flash, midisense lost connection to the board. after i confirmed this message, midisense tries to program addres #0 - and crashes. the same error occurs trying to verify the fw. this looks like a bug of midisense...
I also noticed that the flash process needs allmost 100% of my cpu!
Ahh, I guess a warning message should be displayed, that verify firmware should not be interrupted, or the fw could get damaged!
michu
Post by michu »
yes, another message, ill talk to myself ;)... i guess the problem is this f3$!@g usb-to-midi adapter, which comes without driver and manual, thats why the performance is that bad (>90% cpu use of midisense).. just and idea. anyone tried allready this adapter: http://www.infra-sonic.com/page/midisonic.html ?
michu
Post by michu »
ok, i stopped all cpu intensive tasks (wlan services, virus scanners etc..) and then I retried it. Uploading the firmware is quite timing relevant, if i started midisense too early, i received alot timeouts, after some tries, the firmware upload went fine. after uploading the firmware successfully, midisense tries to verify the firmware. at verifying adress 64 (or 128) midisense just freeze, no error is displayed in gui or in debugview... any hints here?
michu
Post by michu »
Ok I just realized, that vista is not supported due the portmidi lib. we use quite an old version here (15 nov 04), check the changelog:
http://portmedia.svn.sourceforge.net/vi ... iew=markup
So i created an up-to date version of midisense. I also created a version, which does not verify the firmware and a version with an larger timeout (6s).
Ill test this this evening... cheers
Return to “MIDIsense”
