NEW MIDIsense software - and a firmware question
Posts about MIDIsense. open source MIDI sensor platform
michu
Post by michu »
Tataa, I compiled today midisense with the latest wxWindows and portmidi libs with vc2005 - the result is a MUCH faster and more stable version of MIDIsense software. There are no more timeouts when talking to the board. You can grab it here:
http://www.neophob.com/serendipity/inde ... pdate.html
Tested with WinXP SP2, according to the portmidi changelog, it *should* work with vista too - but this is not tested.
Just a question about the RES Firmware... WHERE is the latest firmware for the res board? On the download section, the link for "Here is the v1.2 resistive board hex file for download." points to the file midisense-res.hex as version 1.6. this version works on my midisense... BUT if i download the latest revision of this file (v1.9) midisense does NOT work... any hints about?
michu
Re: NEW MIDIsense software - and a firmware question
Post by michu »
michu wrote:...points to the file midisense-res.hex as version 1.6. this version works on my midisense... BUT if i download the latest revision of this file (v1.9) midisense does NOT work... any hints about?
Ok Revision 1.7 is the latest Firmware that works on the res. board (i call this the green-blinking-led version). revision 1.8 and 1.9 ARE NOT WORKING on a res board... on the revision comment there are also some "adio" comments arround.. guess there is something wrong...
Return to “MIDIsense”
