SokkOS, new modified firmware
Discuss mods, hacks, tweaks, etc.
lorne in canada
Re: SokkOS, new modified firmware
Post by lorne in canada »
Is it possible to transpose a pattern and save it to a different slot, either in pattern or as a transposed pattern saved in a chain?
I'm interested in setting up automatic bass line: pattern 1 x 4, 1 x up a third x2, pattern 2, Pattern1 etc.
bmot
Post by bmot »
I just got my first xoxbox, a used one from xoxshop.de. It will make a perfect companion to my mc-202. I'll be using it as a slave, along with the 202, a hardware sequencer and 2 drum machines. I've got the RE-20 and Proco Rat for effects. SammichSID is also joining the party to complete my live setup (for now - it's never complete of course!).
I'd been doing a lot of reading up before it arrived, and from that I knew the first thing to do was load sokkOS 2.0. I didn't even try the original firmware. I've nothing much to say as yet except a big thank you for creating sokkOS. By the way, is this the right place to post feature requests? I haven't thought of one yet, in fact still trying out all the features that are there, but surely will do at some point.
cheers
bmot
Post by bmot »
ok, following up on my first post above I have a feature request.
EDIT:
i've moved it to a new thread: http://forums.adafruit.com/viewtopic.php?f=13&t=34265
Chris72160
Post by Chris72160 »
Hey,
where can i download SokkOS 1.9.1?
Thanks! :D
Greetz Chris
antto
Post by antto »
the links are on the first post of this thread, altho they look dead
perhaps try sokkos 2.0 http://forums.adafruit.com/viewtopic.php?f=13&t=19336
human fly
Post by human fly »
idea:
how about controls - eg: 'incidence'(?) - somewhere to
regulate the density of events generated by randomize?
ie: density of slides, of accents, of gates
ie: how many slide/acc/gate events you end up with in your run.
you don't need slides to occur as often as gates or accents,
at least, so it would be nice to have a knob to turn, or a value
to input numerically, prior to hitting random - maybe it would be
quite separate from the firmware..how does the random work?
i have something in SE here where i can set a threshold - it is a
simple comparator thing that filters out lower values, so it only
hits when a higher-than value comes in. and i have analogue control
over the compare value, so i can dial in the density of randomization
results.
just an idea.. :(
human fly
Post by human fly »
hey: wot no MIDI out in Edit mode? only just realised this.
think this isnecesary for a viable sequencer of other gear
(mind you, this thread seems dead now)
Return to “x0xm0dz”
