I built the ADIO Kit and I get a flashing green led when i power on.
There is a message (unable locate midisense) I put the chip socket in backwards but I put the chip in correctly. Could this be a potential problem? Desoldering the chip socket has proven to be virtually impossible. What should I do?
problems connecting midisense ADIO with midisense software
you should only be using the most recent software. v1.0c is very old
use v1.3 http://www.ladyada.net/make/midisense/download.html
midisense ADIO board not connecting to midisense software
ok that worked plus I was having a bit of a problem with a faulty midi cinector that came with the Kit. (how do I connect the Parallex ultrasonic sensor up to the midisense ADIO. It shuts it down when I connect it, is there a special connection? Thank you in advance
