Grounding 12V Power Supply With LEDs and Beaglebone
- mrmu
I want to setup the following wiring of the LED strip and N channel MOSFETs but with a separate 12V power supply and BeagleBone Black (obviously powered by separate 5V power supply): https://learn.adafruit.com/rgb-led-strips/usage
I would still ground the Source pin (pin 3) on the MOSFETS to the the Beaglebone, right? And then ground the power supply into that same line?
What would happen if I didn't ground the setup into the Beaglebone, only connecting the 3 MOSFET Gate pins to the I/O pins on the Bone?
Re: Grounding 12V Power Supply With LEDs
You need to connect the grounds together so that you have a common signal reference. Otherwise, the signal from the Bone would be floating relative to the MOSFET gate and operation would be unpredictable.
- mrmu
So I did the setup I outlined before submitting the message (not connecting to the Beaglebone ground, only the 3 R/G/B connections to the I/O pins).
And now my Beaglebone won't turn on. When I give it power, the blue power light flashes quickly and that's it.
Is it fried? Is it possible by not connecting to the Beaglebone ground that 12V somehow ran through the gate pins on the MOSFETs and into the Bone?
Post a photo of how you had everything connected. That kind of damage is not common. But with no common ground all bets are off.
A good general rule of thumb with working with separately powered circuits is that the ground connection should be the first one you make.
- mrmu
Here's a picture.
I tested with a multimeter, and the voltage coming out of the MOSFETs' gate pins is nominal (~200mV)
Any idea why my Beaglebone won't turn on? Seems almost impossible that this fried it, right?
- Attachments
- wiring_diagram.JPG (496.67 KiB) Viewed 435 times
It may not work, but I don't believe that configuration would be capable of frying the Bone.
- mrmu
Right, it actually did it to 2 Beaglebones. Both of which won't power on now.
Any idea? I've done some searching and couldn't find anything.
Re: Grounding 12V Power Supply With LEDs and Beaglebone
I run it by some of the other engineers and see if they have any ideas.
- adafruit2
oof not sure. it would be surprising if it really did damage it. but I'm also a little scared to try it on my 'bone. you could try looking for any console output? also check your polarity on the 12V adapter, make sure you didnt mix + and -!
- mrmu
Yeah, I checked the polarity on the power supply. It's good.
Previously I wired it up with the ground connection to the Bone and it didn't hurt the board. Only when I didn't connect the circuit to the Bone GND, did it apparently hurt my boards.
Another thing is that the circuit was very unstable, and when I touched the MOSFETs with my finger the lights would flickr or randomly change colors.
I wouldn't expect that any damaging current could conduct back through the gate of the MOSFET. You might want to contact the BBB folks to see if they have any ideas.Previously I wired it up with the ground connection to the Bone and it didn't hurt the board. Only when I didn't connect the circuit to the Bone GND, did it apparently hurt my boards.
With no common signal ground, the MOSFET inputs are effectively floating and would be easily influenced by things like that.Another thing is that the circuit was very unstable, and when I touched the MOSFETs with my finger the lights would flickr or randomly change colors.
