I have followed what you told to do at https://learn.adafruit.com/spokepov/customize . However, when I pressed 'connect,' this wheel panel which you mentioned didn't showed up in my screen, and therefore I couldn't do it.
Another problem is that the program crashes when I import a BMP image file.
I've tried both Mac OS, Windows with my mac and with a windows PC. Therefore I think that the problem isn't my POV.
Could I please get an answer in 24hours? I have this school festival and I have to solve this problem quickly as possible. Thanks.[
wxSpoke POV program problem
- messigod77
- Attachments
- This is the picture of wxSpoke POV which I mentioned that was missing a wheel panel.
- spoke pov.tiff (82.59 KiB) Viewed 3000 times
- adafruit_support_rick
Re: wxSpoke POV program problem
Please post some pictures of your connections.
Also, post some pictures of both sides of your USBtinyISP board.
- messigod77
These are some photos of the tiny ISP board you've asked.
I've also posted some pictures of the other parts of my POV just in case you need them.
See, I've got this really big project that I have to finish it by today so I'd be really really pleased if you could reply it quickly as possible. Thanks.
- Attachments
- front part
- pov capture3.tiff (520.69 KiB) Viewed 2972 times
- front part
- pov capture2.tiff (289.58 KiB) Viewed 2972 times
- front part
- pov capture1.tiff (558.99 KiB) Viewed 2972 times
- messigod77
Extra photos
- Attachments
- pov capture6.tiff (675.64 KiB) Viewed 2972 times
- pov capture5.tiff (603.7 KiB) Viewed 2972 times
- back part
- pov capture4.tiff (633.36 KiB) Viewed 2972 times
You've got the 6-pin cable on backwards - the red wire should be on the other side. Try switching the cable around
