Shrinked TV b gone
- lyczewskiand
Shrinked TV b gone
Hello and welcome.
I wonder if I could shrink this tv-b-gone v1.2 https://learn.adafruit.com/tv-b-gone-kit/parts-list
to make it as small as possible to fit inside keychain flashlight http://www.clickonway.com/wp-content/up ... hain-0.jpg
I would like to use SMD transistor.
only 2 IR LEDs driven by one transistor (what should i do with unconnected pins? connect them to ground?)
no indicator green LED (leave unconnected pin or connect to GND?)
Use internal uC oscillator which is quite accurate?
Regards
Regards
Re: Shrinked TV b gone
You should be able to shrink it considerably with just a 2-led output.. Leave the unused pins unconnected. Don't connect them to ground.
- lyczewskiand
Maybe i will find way to disable those pins in source code ;)
- Franklin97355
You don't need to do anything with the pins, just don't use them and make your board smaller.Maybe i will find way to disable those pins in source code ;)
- lyczewskiand
Thanks a lot for your respond.
Now i need to collect all items and probably I will post my device here.
- lyczewskiand
Do you know how to change source code to use internal uC oscillator? Or it is only a matter of leaving fusebits to use internal clock oscillator because maybe (i don't know) program already has a "#define #define F_CPU 8000000UL" ?franklin97355 wrote: You don't need to do anything with the pins, just don't use them and make your board smaller.
- lyczewskiand
Nice build! I don't think I've ever seen one quite that small.
- lyczewskiand
I used this 3 led keychain
http://imgur.com/a/khotS
I designed a pcb to match with button placement.
Are you going to sell one to jwz?
http://www.jwz.org/blog/2013/03/tv-b-gone-y-u-so-big/
- lyczewskiand
Didn't know that someone would pay 200$ for that.
Thread is 3 years old :D
And i cannot post a comment that I've made one :D
Your build in featured on the blog: https://blog.adafruit.com/2015/09/04/fr ... -keychain/
- lyczewskiand
WOW. Thanks ;) Can i get some promo or free items for featured project :D ?adafruit_support_bill wrote:Your build in featured on the blog: https://blog.adafruit.com/2015/09/04/fr ... -keychain/
I posted it on Instructables. If you don't mind I'll post link here http://www.instructables.com/id/TV-B-Gone-Keychain/ It's featured :)
It's almost 5k views and over 100+ favourites
EDIT___________________
Look at my friends' project http://mdiy.pl/latarkowy-tv-b-gone-duzej-mocy/?lang=en
This is INSANE!!!
