trying to put new firmware on mode machines xoxbox
maclaren1976
Post by maclaren1976 »
Hi there,
i'm trying to put new firmware (sokkos 2.0) on my mode machines xoxbox, but it doesnt seem to work.
i've installed conbox and the vcp driver.
when i flash the new firmware, conbox says everything is okay and it worked, but when i reboot
there is no Sokkos 2.0 on my box.
anyone know what i could be doing wrong?
thanks!
antto
Re: trying to put new firmware on mode machines xoxbox
Post by antto »
if the firmware works - it has been flashed
i assume you are looking at what BANNED displays when you connect to the firmware afterwards..
when you connect to the firmware with BANNED, it tries to distinguish what firmware it is, but this is done using new messages which BANNED introduces into the protocol, and most firmwares (especially those which run on the atmega162) don't support them
as a result, BANNED cannot tell what the FW is, so it would print something like "(auto) Adafruit 1.05 compatible"
but if you flash sokkos2, and the x0xb0x works - you have succesifully flashed sokkos2
hope this helps
maclaren1976
Antto thanks for the reply.
the thing is that i know the flash doesn't work because i don't get any of the expected
Sokkos 2.0 functionality. (I also own a non mode machines xoxbox, and there i successfully flashed sokkos2 to)
i must be doing something wrong, but i can't figure out what so far..
antto
Post by antto »
did BANNED successifully flash the hex?
maclaren1976
Sorry but i'm not sure what that means . . .
Return to “x0xm0dz”
