Hi all,
This is my first time ordering PCB boards, so I am hoping my trouble is from a lack of understanding (and that someone here can help me out).
I am attempting to place an order for RC1a using the pre-tiled gerber files that the little lady put together. My problem is, I can't figure out how to successfully do this. 4PCB seems to require that I go through their FreeDFM thing first, but I am having trouble accurately labeling each of the files in the Gerber zip file.
I am assuming every piece of information they need is included in these files.....is there a conversion I am supposed to do prior to sending in the files?
BANNED
EDIT: FreeDFM not FreeDRM (albeit ironic, no?)
Trouble ordering from 4PCB
- sturnfie
There is another thread on this topic: http://www.ladyada.net/forums/viewtopic.php?t=3182
The recommended solution was to contact a sales rep.
As for my own attempts, I got FreeDFM to accept the files and am waiting to hear back on a report. I found the information I "needed" using Gerbview and wikipedia:
http://www.softwarecompanions.com/gerbview.html
http://en.wikipedia.org/wiki/Gerber_File
BANNED
BANNED
- sturnfie
The report I got back when using www.4PCB.com indicated that it would cost me $400 a unit for a single unit, or $135 each for 3!!! Tooling costs aside, that was a bit more than what I would find reasonable.
Luckly, www.33each.com was mentioned, and although it seems to be the same company, I was able to get 3 sets of the boards for $114.
BANNED
BANNED
sturnfie,
1. What did you come up with for the file descriptions?
I just came across this project and have been trying to order the PCB boards through www.33each.com. I didn't find the answers in the webpages you posted.
2. Are the files on the website ready to be sent to 33each as is, or do they need to be converted?
I tried calling the 1-800 # but was sent back to the webpage.
3. I am using the 4" by 12.8 inch dimensions. Is this correct?
4. Does anyone have a screen shot of their order for the PCB boards and components?
1 - File extensions:
Software: Eagle File Extension Description
cmp Top Copper
sol Bottom Copper
stc Top Soldermask
sts Bottom Soldermask
plc Top Silkscreen
pls Bottom Silkscreen
drd NC Drill
Software: Orcad File Extension Description
top Top Copper
bot Bottom Copper
smt Top Soldermask
smb Bottom Soldermask
sst Top Silkscreen
ssb Bottom Silkscreen
thruhole.tap NC Drill
Software: Protel File Extension Description
gtl Top Copper
gbl Bottom Copper
gts Top Soldermask
gbs Bottom Soldermask
gto Top Silkscreen
gbo Bottom Silkscreen
drl NC Drill
2 - The files can be sent as-is
3 - Per my previous post: 82mm(3.23") X 210mm(8.27")
4 - no
cmp Top Copper
sol Bottom Copper
stc Top Soldermask
plc Top Silkscreen
drd NC Drill
top Top Copper
bot Bottom Copper
smt Top Soldermask
sst Top Silkscreen
gtl Top Copper
gbl Bottom Copper
gts Top Soldermask
gto Top Silkscreen
drl NC Drill
4 - no
- treepcb
Re: Trouble ordering from 4PCB
We supply one stop pcb&pcba service, our professional and skilled team will work out time critical,high performance pcb&pcba solutions quickly after understanding your specific requests.
