Bass Boost BANNED???
JRock
Post by JRock »
Bass boost mod seems BANNED. I put a switch on it. I had to put the wires to the board on 2+5 to make it work. There seems to be a little difference but I was kind of expecting something dramatic. Maybe I didn't do it right? My x0x still sounds great, but I was expecting more of an impact after I put this mod in. My first mod... So if anybody has the same result, or an idea of how I did it wrong I would love to hear from you.
JRock
Re: Bass Boost BANNED???
Post by JRock »
Does it matter which side of the caps I install the switch on? Right now I have them it in between the caps C20/C21and the resistors R121/R122... anybody know before I solder the new switch on? (The first one had a little plastic screw post and as careful as I was I still managed to strip it out..JUNK!)
hamburgers
Post by hamburgers »
it's not a very exciting mod
JRock
Post by JRock »
Wonder if there's some different value to really Kick it up?
Thanks for the reply.
JRock
Post by JRock »
Sounds pretty sweet now with some old metal distortion in the loop!!
JRock
Post by JRock »
A lot more noticeable with the VCO frequency modulation
alex_dubinsky
Post by alex_dubinsky »
The problem is in the BA6110. Changing the capacitors changes the ba6110 input a lot, but the output isn't so different. I wonder if BA662 (or different batches of BA6110) would be less of a bottleneck.
legionhwp
Post by legionhwp »
Hmmm, I did the "stock" bass boost mod from the subatomic and ladyada guide and I think it's fantastic.The only setting where it doesn't make things sound "better" to my ears is when i also switch on the distortion mod I did. I have a switch to go from stock to bass boost but overall highly recommend this as one of the easiest and more useful mods.
YMMV I guess
D_
tempomaster
Post by tempomaster »
I just did this mod, and honestly, I can't tell the difference. I didn't do extensive testing, but on the one pattern that I recorded and did a frequency analysis on, the low-end is pretty near identical on both. There was a boost at 5k, but that's not a bass frequency.
tempomaster
I'm not sure what all I did, but now I can definitely hear the bass boost.
::shrugs::
Luap
Post by Luap »
I've done this mod on 2 different x0xb0xes. Although I used the same value caps on both, the brands and voltage rating (and physical size) of the caps were quite different. One x0x definitely has more bass boost than the other..
That said, its still a subtle mod. But play the x0x out over a BIG sound system, and im sure you wont fail to notice it then ;)
Return to “x0xm0dz”
