NEOPIXEL brightness control
kit_ho
Re: NEOPIXEL brightness control
Post by kit_ho »
*poowfftt* mind blown, why didn't I thought about that! Something as simple as that, is very enlightening, thanks again! XD
UnknownBoyPT
Post by UnknownBoyPT »
Hello Guys,
I'm also very new at this subject like arduino and leds but I have to do a work for my master degree so I really have to figure something out.
I've this code, and I'd like to make it "breathe" in another color but I couldn't figure it out. Right now it just breathes in white. What should I change?
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN 6
#define LEDS 24
const int  CYCLE_MILLISECONDS = 5000; // 5 second breathing cycle.
const uint8_t KEYFRAMES[]  = {
  // Rising
  20, 21, 22, 24, 26, 28, 31, 34, 38, 41, 45, 50, 55, 60, 66, 73, 80, 87, 95,
  103, 112, 121, 131, 141, 151, 161, 172, 182, 192, 202, 211, 220, 228, 236,
  242, 247, 251, 254, 255,
  // Falling
  254, 251, 247, 242, 236, 228, 220, 211, 202, 192, 182, 172, 161, 151, 141,
  131, 121, 112, 103, 95, 87, 80, 73, 66, 60, 55, 50, 45, 41, 38, 34, 31, 28,
  26, 24, 22, 21, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20, 20,
unsigned long lastBreath = 0;
int keyframePointer = 0;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(LEDS, PIN, NEO_GRB + NEO_KHZ800);
  strip.begin();
  strip.show();
  int numKeyframes = sizeof(KEYFRAMES) - 1;
  float period = CYCLE_MILLISECONDS / numKeyframes;
  unsigned long now = millis();
  if ((now - lastBreath) > period) {
    lastBreath = now;
    for (int i = 0; i < strip.numPixels(); i++) {
      uint8_t color = (127 * KEYFRAMES[keyframePointer]) / 256;
      strip.setPixelColor(i, strip.Color(KEYFRAMES[keyframePointer], KEYFRAMES[keyframePointer], KEYFRAMES[keyframePointer]));
    strip.show();
    // Increment the keyframe pointer.
    if (++keyframePointer > numKeyframes) {
      // Reset to 0 after the last keyframe.
Last edited by adafruit_support_bill on Fri Jun 24, 2016 1:11 pm, edited 1 time in total.
Reason: Please use [code] tags when submitting code to the forums
This line sets the R, G and B component of the color to all the same value, so it is white.
If you want a different color, first you need to define what the RGB components of that color are, then scale the values proportionally for the fade.
UnknownBoyPT
Could you please explain me how could I do that? Because I already changed that line to something similar to this:
strip.setPixelColor(i, 255, 0, 0);
But then the lights just stay in fixed red color and not breathing anymore
strip.setPixelColor(i, KEYFRAMES[keyframePointer], 0, 0);
UnknownBoyPT
Thank you very much! And what should I do to change it to other colors? Like Yellow, Pink, or other colors with RGB color code? Because I was trying with some of them but it didn't work.
The general formula is:
strip.setPixelColor(i, (Red * KEYFRAMES[keyframePointer]) / 255, (Green* KEYFRAMES[keyframePointer]) / 255, (Blue* KEYFRAMES[keyframePointer]) / 255);
UnknownBoyPT
adafruit_support_bill wrote:The general formula is:
Thank you so much! It worked perfectly!
One last question, is it possible to make it "breathe" with different breathing? In another words, as we human, we always breathe differently, one more intense or less, and so on. Is is possible to do the same here? To make it look more "natural" instead of just fade in and fade out?
One thing that would be fairly straightforward to do is to randomize the timing a bit. Changing CYCLE_MILLISECONDS will alter the rhythm of the breathing. The random function is documented here: https://www.arduino.cc/en/Reference/Random
UnknownBoyPT
adafruit_support_bill wrote:One thing that would be fairly straightforward to do is to randomize the timing a bit. Changing CYCLE_MILLISECONDS will alter the rhythm of the breathing. The random function is documented here: https://www.arduino.cc/en/Reference/Random
Thank you! I'll check on that!
kenan03
Post by kenan03 »
this is my first project and it will include a strip segment of neopixel strip as well as two nexopixel rings (the 16 pixel version). I was wanting to make the entire set of lights have a light blue color breathing effect. I was directed to @adafruit_support_rick who provided a very helpful code for a breathing light pattern (quoted below). How would I need to modify this code to make it work with the setup I have above (one strip and two rings all connected). Thank you in advance!
Albert
adafruit_support_rick wrote:You guys might want to have a look at the breathing sketch I wrote a while ago.
BreatheRightStrip.ino:
#include "Adafruit_NeoPixel.h"
#include "SPI.h"
//Demonstrates "breathing" effect on NeoPixel Strip
#define LED_PIN  6
#define N_LEDS  16
Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_LEDS, LED_PIN, NEO_GRB + NEO_KHZ800);
uint8_t LED_Breathe_Table[]  = {   80,  87,  95, 103, 112, 121, 131, 141, 151, 161, 172, 182, 192, 202, 211, 220,
				  228, 236, 242, 247, 251, 254, 255, 255, 254, 251, 247, 242, 236, 228, 220, 211,
				  202, 192, 182, 172, 161, 151, 141, 131, 121, 112, 103,  95,  87,  80,  73,  66,
				   60,  55,  50,  45,  41,  38,  34,  31,  28,  26,  24,  22,  20,  20,  20,  20,
				   20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,
				   20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  20,  22,  24,  26,  28,
				   31,  34,  38,  41,  45,  50,  55,  60,  66,  73 };
#define BREATHE_TABLE_SIZE (sizeof(LED_Breathe_Table))
#define BREATHE_CYCLE	 6000		/*breathe cycle in milliseconds*/
#define BREATHE_UPDATE	 (BREATHE_CYCLE / BREATHE_TABLE_SIZE)
  // Start up the LED strip
  strip.begin();
  // Update the strip, to start they are all 'off'
  strip.show();
  int cycle;
  for (cycle=0; cycle < 4; cycle++) {
    uniformBreathe(LED_Breathe_Table, BREATHE_TABLE_SIZE, BREATHE_UPDATE, 256, 256, 256);
    sequencedBreathe(LED_Breathe_Table, BREATHE_TABLE_SIZE, BREATHE_UPDATE, 256, 256, 256);
void uniformBreathe(uint8_t* breatheTable, uint8_t breatheTableSize, uint16_t updatePeriod, uint16_t r, uint16_t g, uint16_t b)
  int i;
  uint8_t breatheIndex = 0;
  uint8_t breatheRed;
  uint8_t breatheGrn;
  uint8_t breatheBlu;
  for (breatheIndex = 0; breatheIndex < breatheTableSize; breatheIndex++) {
    for (i=0; i < strip.numPixels(); i++) {
      breatheRed = (r * breatheTable[breatheIndex]) / 256;
      breatheGrn = (g * breatheTable[breatheIndex]) / 256;
      breatheBlu = (b * breatheTable[breatheIndex]) / 256;
      strip.setPixelColor(i, breatheRed, breatheGrn, breatheBlu);
    strip.show();   // write all the pixels out
    delay(updatePeriod);
void sequencedBreathe(uint8_t* breatheTable, uint8_t breatheTableSize, uint16_t updatePeriod, uint16_t r, uint16_t g, uint16_t b)
  int i;
  uint8_t breatheRed;
  uint8_t breatheGrn;
  uint8_t breatheBlu;
  uint8_t sequenceIndex;
      sequenceIndex = (breatheIndex + (i*4)) % breatheTableSize;
      breatheRed = (r * breatheTable[sequenceIndex]) / 256;
      breatheGrn = (g * breatheTable[sequenceIndex]) / 256;
      breatheBlu = (b * breatheTable[sequenceIndex]) / 256;
The only thing you need to change is this line:
#define N_LEDS  16
Change N_LEDS to the total number of pixels in your strip plus the rings.
Bazeman
Post by Bazeman »
I have been trying to get a effect with the neopixels but I won't get it right... At page 4 adafruit_support_rick responded to Chargerdude70 who had added some code to the library individually control each pixel in brightness.. I have tried to add this code also to the library but then afterwards the sketch won't compile anymore.. Can someone exactly tell what lines I have to add were to make this sketch to work:
//chaseFade....Make lights fade from low to high intensity while lighting one after another
const int ledNum = 13; // Number of LED's
const int ledPin = 6; // ATtiny85 LED signal output pin #
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(ledNum, ledPin);
uint32_t Blue = pixels.Color(0, 255, 0);
uint16_t i, l;
#define DELAY 30 // Time delay between Pixels
  pixels.begin();
  pixels.show();
  pinMode(ledPin, OUTPUT);
// chaseFade
  int chase = 0;
  uint8_t brightIncrement = 255 / pixels.numPixels();
  for (chase; chase < 5; chase++) {
    for (i = 0; i < ledNum; i++) {
      pixels.setPixelColor(i, Blue, ((i + 1) * brightIncrement));
      pixels.show();
      delay(DELAY);
      pixels.setPixelColor(i, 0, 0, 0);
      pixels.show();
    delay(1000);
I hope you guys can help
You should post the errors you're getting instead of just saying "it doesn't compile".
This line won't compile: There is no setPixelColor function that takes 3 arguments:
Bazeman
Post by Bazeman »
Hi Rick,
Thanks for the reply.
I know that the line in the code won't compile because it is not set in the standard Neopixel library. My question foremost is where exactly I have to put the extra arguments in the .h and .ccp file.
If I'm correct this should be added to .h somewhere:
setPixelColor(uint16_t n, uint32_t c, uint16_t brightness),
And this should be added to .ccp somewhere:
// Set pixel brightness individually using seperate R,G,B components:
void Adafruit_NeoPixel::setPixelColor(uint16_t n, uint8_t r, uint8_t g, uint8_t b, uint16_t brightness) {
  setPixelColor(n, (brightness*r/255) , (brightness*g/255), (brightness*b/255));
// Set pixel brightness individually using a 'packed' 32-bit RGB color:
void Adafruit_NeoPixel::setPixelColor(uint16_t n, uint32_t c, uint16_t brightness) {
   uint8_t
      r = (uint8_t)(c >> 16),
      g = (uint8_t)(c >>  8),
      b = (uint8_t)c;
  setPixelColor(n, r, g, b, brightness);
Sorry for the noob question.... :-{ But thanks for any help!
