Serial1.available()=0 if Xbee adapter attached
XBee projects like the adapter, xBee tutorials, tweetawatt/wattcher, etc. from Adafruit
lriche
Post by lriche »
I have a Leonardo with a Xbee adapter connected to the serial Rx an Tx ports. The code below seems to work at random at times. Particularly, if I remove the Rx Tx connections first. When I print the value of Serial1.available it is 0;
I read somewhere that the Rx Tx pin must be disconnected before uploading the code. If this is true my question is why? How can I make a reliable system if I constantly have to remove the pins to get my code to run? There has to be a workaround.
int led = 13;
  Serial1.begin(9600);
  Serial.begin(9600);
  while(!Serial1 && millis()<5000) {
    //wait for serial monitor to connect
  Serial.print(Serial1.available()); // Equals 0 all the time
  while(Serial1.available()){
    digitalWrite(led, HIGH);
    Serial1.print('H');
    delay(500);
    digitalWrite(led, LOW);
    delay(500);
Franklin97355
Re: Serial1.available()=0 if Xbee adapter attached
Post by Franklin97355 »
How do you have things connected and what are you sending to the xbee?
lriche
Post by lriche »
I have the xbee is connected to arduino via xbee adapter. I have Rx -> Tx, Tx -> Rx, 5v -> 5v GRN -> GRN. I am just sending test text to the Xbee.
Return to “XBee products (discontinued)”
