Dear good afternoon , I have problems with one of the XBee ( 40c673df ) purchased from you
XBee Pro Module - ZB Series 2SC - 63MW with Wire Antenna - XBP24CZ7WIT - 004
I have to reset it to communicate and then set it .... Then to configure , do not take me the number of red.-
Please can you help me with this problem ?.
Thank you
XBee Pro Module error number of red
- adafruit_support_rick
Re: XBee Pro Module error number of red
Please post clear, detailed pictures of your soldering and wiring
- Adichip
First of all I thank you for your attention.
The assembly is next, I tried everything to make it work and I have no luck. Probe examples of the manufacturer's website but seems to have a problem with the module.
I would like to see if they can give me an example with the following:
1) Coordinator, which has enabled a digital output to refresh the input status of the Router.
2) Router, which has enabled a digital input.
With an example so you could try directly upload files to open with the X-CTU and this load on each Xbee.
To rule out serious the problem is the software.
Thank you very much in advance.
Best regards.
Best regards.
- Attachments
- ebhlaplibedoclnf.png (228.76 KiB) Viewed 2601 times
You need a resistor on that LED. Otherwise, it is a direct short circuit to ground, which will damage the pin on the XBee.
Have you configured the XBees for pin-passing in X-CTU?
- Adichip
Good morning, forgive my ignorance, I do not understand your question:
You have you any example that can be used to test the modules?
Thanks in advance.
Thanks in advance.
- Adichip
Good morning Rick, first of all I appreciate the time you're engaging my problem. I wanted to let you know that the module that you have to buy the firmware version 802.14.11: 45 and so I could figure must be updated to version 802.15.4
Any help instructive to update to this latest version modules ?
I think my problem arises from this detail.
Thank you very much and good start to the week.
Best regards.
Adichip
Best regards.
Adichip
I think you're going to have to go to the Digi support forums. We don't know a lot about XBees here.
http://www.digi.com/support/forum/
