Fixed the new notes on the end step *not* to have slide and accent turned on.
(That was a relative new bug .. I overlooked a case doing some code cleanup. Meanwhile I should have learned that most of the code is already compact, and if a change saves bytes, it is very probable doing so, because I allowed the compiler to optimize away something needed. )
The doubleclick F works here as intended. It sets all notes of the current pattern
with the current pattern length(!) to middle C.
I changed that to RESTs.
It does *not* change the length of empty pattern, so an empty pattern has to be "blown up" once with one of the step modes.
That might not be what you want to have, but as now *all* modifiers from the randomizer obeys the pattern length doubleclick F does that also. Just being consequent.
Of course that could be changed if it seems to be more useful.
List of changes for version MarOs15-V1.76
- doubleclick F in randomizer mode now sets pattern to all REST, not middle C
- a new entered note on the "stop" step does not have ACCENT and SLIDE set any more
Personally I don't like the double click at all and would prefer a different solution.
My idea is to use some "free" keys in pattern edit during stop mode. In that sub mode you load patterns from the 1..8 places.
So "REST" could be added there to load an fixed "all Rest" Pattern. May be ACCENT and SLIDE could provide two further useful default patterns.
I'd have to remove the doubleclick F for that (both methods together would not fit).
What do you think?
