Corrdinator - Router - Router Communication
XBee projects like the adapter, xBee tutorials, tweetawatt/wattcher, etc. from Adafruit
sezerk
Post by sezerk »
Hi everyone,
I am working on Xbee (XB24-Z7UIT-004) nowadays. I got 3 xbee, 3 arduino. I want to send a massege from one arduino to the others.
When I configured the coordinator as "Coordinator AT" and the other as "Router AT", everything is OK.
But when I configured them "Coordinator API" and the other as "Router API", it is not OK. After all, I configured the other arduino as "End Device API". But I failed again.
I can see the comminication between 3 arduinos as below. But I could not send message.
Is there anybody who can help me?
You can see the code below
// TRANSMITTER
#include <XBee.h>
XBee xbee = XBee();
void setup()
 pinMode(13, OUTPUT);
 Serial.flush();
 xbee.setSerial(Serial);
 xbee.begin(Serial);
void loop()
 // Create an array for holding the data you want to send.
 uint8_t payload[] = { 255, 128 };
 // Specify the address of the remote XBee (this is the SH + SL)
 XBeeAddress64 addr64 = XBeeAddress64(0x0013A200, 0x40BAA50C);
 // Create a TX Request
 ZBTxRequest zbTx = ZBTxRequest(addr64, payload, sizeof(payload));
 // Send your request
 xbee.send(zbTx);
 digitalWrite(13, HIGH);
 delay(100);
 digitalWrite(13, LOW);
 delay(100);
// RECEIVER
#include <XBee.h>
XBee xbee = XBee();
ZBRxResponse ZBRx16 = ZBRxResponse();
#define MAX_FRAME_DATA_SIZE 110
bool toggle = false;
void setup()
 Serial.flush();
 xbee.begin(Serial);
void loop()
   xbee.readPacket();
   if (xbee.getResponse().isAvailable())
      toggle = !toggle;
      // got something
      xbee.getResponse().getZBRxResponse(ZBRx16);
      //if (ZBRx16.getData(1) == 255)
        digitalWrite(13, toggle);
What I am doing wrong?
Franklin97355
Re: Corrdinator - Router - Router Communication
Post by Franklin97355 »
This might be a question better asked in the Digi forums.
Return to “XBee products (discontinued)”
