hello!!
i make my personal reader sim....all see in my web:
http://od-lambda.blogspot.com/2009/09/ ... s-232.html
and my main web blog is:
I have read problem with the program pySIMREADER in windows XP pro with sp2, the next error is:
File "pySimReader.py", line 267, in buttonConnectReader
File "pySIMserial.pyc", line 111, in connectReader
File "pySIMserial.pyc", line 160, in openSession
TypeError: ord() expected a character, but string of length 0 found
File "pySIMserial.pyc", line 143, in openSession
File "serial\serialutil.pyc", line 166, in __init__
File "serial\serialwin32.pyc", line 49, in open
serial.serialutil.SerialException: could not open port COM1: (5, 'CreateFile', 'Acceso denegado.')
The circuit is all right!!!the com port is correct! i try with the ft232r(usb-232 converter) and report the same error!The vcc is right....
i use rs-232 conection directly from motherboard...no usb-rs232 adapter...
I try with a edgeport serial converter...and the same error.......i mind this software is not dont run?:(
the sim card are correct...i try to T-MOBILE,AMENA,MOVISTAR AND ONE SPECIAL SIM CARD TO TEST.
I use a xtal 3.579545 MHz....when the original esquematic is a 3.57Mhz?????
i dont found the xtal 3.57MHz and the orginal proyect of the reader sim use a 3.579545MHz(see the sch of the simscan)
In the simscan cant run...
I see the com port conexion and is 9600 8 N 1....the rest disabled.
I would like to put my scheme in the main website so that another person could make the board "free" but C.C(commons creative) ... please contact me the author of the page or design.
Please if you have interested in my proto-pcb contact to me in the emaiL:
[email protected]
The design is in eagle cad soft.
Very thanks!!
OD-LAMBDA READER SIM PROTO PCB!!!!DONT RUN HELP!THANKS!
