Tv b gone wont work
- Mish12mish12
Tv b gone wont work
Hi i soldered every thing on my tv b gone and it wouldn't work the green led doesn't flash nor does the ir what should i do ?
- Mish12mish12
Re: Tv b gone wont work
i have checked everything with a multimeter for shorts and also put in new batteries and that did not help
- Franklin97355
Could you post large (less than 1meg), clear, detailed pictures of both sides of your board showing any soldering you have done and the connections to it?
- Mish12mish12
Although the solder joints are really bad looking i tested everything for continuity with my multimeter and there was no shorts and everything was fine
- Attachments
- IMG_20170802_150738765.jpg (983.54 KiB) Viewed 2851 times
- IMG_20170802_151037812_HDR.jpg (895.9 KiB) Viewed 2851 times
- Mish12mish12
ill fix all the solder joints when my new soldering iron arrives because my old one had a broken tip and was pretty cheap from the first place ill be sure to update on if it works or not
Thank you
Thank you
- Mish12mish12
Hi I fixed all the solder joints made sure again with the multimeter that nothing is shorting and it still won't work should I just return it to where I got it from ?
- imhavoc
I ordered two TV-B-Gone kits from Amazon.com
One works. One does not. Testing showed that one of the microprocessors is defective.
Is there a way to get a replacement microprocessors for this kit?
- Franklin97355
Contact the Amazon seller and ask them.
- imhavoc
Amazon will replace the complete item. I will have to return the complete, assembled and tested unit. I would MUCH rather just purchase a replacement microcontroller if possible.... Oh, wait....
I requested a refund from Amazon, then placed a new order for a new, kit. AFTER the new kit arrives, I can return the defective microprocessor with the unassembled kit and I'll be in business!
Thank you!
Thank you!
