SMT RGB 5050 LED + 5050 LED breakout PCB
MiniPOV4 and previous versions
louis007
Post by louis007 »
Hi i have bought the following
- 5050 LED breakout PCB - 10 pack!
- SMT RGB 5050 LED - 10 pack (there is text on te back, but thats disappeared 80%, i dont know if tthat are the instructions?)
I have no clue what the best manner is to put them together, and i cant find any good youtube video.
Can anybody tell our direct me in the good direction
And yes im a newbie :)), and love the feedback.
Re: SMT RGB 5050 LED + 5050 LED breakout PCB
Not much to it. There are 6 pins on the chip and 6 pads on the PCB. Line them up and solder.
If you scroll down to the "TECHNICAL DETAILS" section of the product description, there will be a pinout diagram showing which pins are which. (Note the notch in one corner to help you orient the chip) https://www.adafruit.com/product/619
As the diagram shows, there are 3 individual LEDs on the chip. You can connect these the same as you would connect three individual LEDs: https://learn.adafruit.com/all-about-leds
Note that the Vf of the red LED is lower than the green or the blue, so your resistor calculation will be different as well.
louis007
Post by louis007 »
Thanks for the info, and indeed not that difficult :))
Return to “MiniPOV”
