Can't get 8x8 minimatrix to work anymore
Our weekly LIVE video chat. Every Wednesday at 8pm ET!
joosteerbeek
Post by joosteerbeek »
I recently got the Adafruit 8x8 red 0,8"matrix. I'm using it with the Arduino Nano. Last week I got it to work with the example code. But this week the matrix won't do anything, with that same code. I added some println's to test where it goes wrong. And it seems to stop working after the code says
matrix.begin(0x70);
You can see that in the serial monitor test1 does print, but test2 doesn't... If I comment out matrix.begin(0x70); then test3 prints as well. just one time.
#include <Adafruit_LEDBackpack.h>
#include <gfxfont.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SPITFT.h>
#include <Adafruit_SPITFT_Macros.h>
#include <Wire.h>
  This is a library for our I2C LED Backpacks
  Designed specifically to work with the Adafruit LED Matrix backpacks
  ----> http://www.adafruit.com/products/872
  ----> http://www.adafruit.com/products/871
  ----> http://www.adafruit.com/products/870
  These displays use I2C to communicate, 2 pins are required to
  interface. There are multiple selectable I2C addresses. For backpacks
  with 2 Address Select pins: 0x70, 0x71, 0x72 or 0x73. For backpacks
  with 3 Address Select pins: 0x70 thru 0x77
  products from Adafruit!
Adafruit_8x8matrix matrix = Adafruit_8x8matrix();
  Serial.println("8x8 LED Matrix Test");
  Serial.println("test1");
  matrix.begin(0x70);  // pass in the address
  Serial.println("test2");
static const uint8_t PROGMEM
  smile_bmp[] =
  { B00111100,
    B01000010,
    B10100101,
    B10000001,
    B10100101,
    B10011001,
    B01000010,
    B00111100 },
  neutral_bmp[] =
  { B00111100,
    B01000010,
    B10100101,
    B10000001,
    B10111101,
    B10000001,
    B01000010,
    B00111100 },
  frown_bmp[] =
  { B00111100,
    B01000010,
    B10100101,
    B10000001,
    B10011001,
    B10100101,
    B01000010,
    B00111100 };
  Serial.println("test3");
  matrix.clear();
  matrix.drawBitmap(0, 0, smile_bmp, 8, 8, LED_ON);
  matrix.writeDisplay();
  delay(500);
  matrix.clear();
  matrix.drawBitmap(0, 0, neutral_bmp, 8, 8, LED_ON);
  delay(500);
  matrix.clear();
  matrix.drawBitmap(0, 0, frown_bmp, 8, 8, LED_ON);
  delay(500);
  matrix.clear();      // clear display
  matrix.drawPixel(0, 0, LED_ON);
  matrix.writeDisplay();  // write the changes we just made to the display
  delay(500);
  matrix.clear();
  matrix.drawLine(0,0, 7,7, LED_ON);
  delay(500);
  matrix.clear();
  matrix.drawRect(0,0, 8,8, LED_ON);
  matrix.fillRect(2,2, 4,4, LED_ON);
  delay(500);
  matrix.clear();
  matrix.drawCircle(3,3, 3, LED_ON);
  delay(500);
  matrix.setTextSize(1);
  matrix.setTextWrap(false);  // we dont want text to wrap so it scrolls nicely
  matrix.setTextColor(LED_ON);
  for (int8_t x=0; x>=-36; x--) {
    matrix.clear();
    matrix.setCursor(x,0);
    matrix.print("Hello");
    delay(100);
  matrix.setRotation(3);
  for (int8_t x=7; x>=-36; x--) {
    matrix.clear();
    matrix.print("World");
    delay(100);
  matrix.setRotation(0);
The wires are connected as followed:
See the image..
I hope you can help me with this!
Franklin97355
Re: Can't get 8x8 minimatrix to work anymore
Post by Franklin97355 »
Can you post a picture of the other side? Your soldering could use a reflow to completely wet the pin and pad for good connections.
joosteerbeek
franklin97355 wrote:Can you post a picture of the other side? Your soldering could use a reflow to completely wet the pin and pad for good connections.
Okay. I will do that on thursday.
joosteerbeek
Hereby the picture
Franklin97355
Check out this Soldering Guide and redo your connections and see if that helps.
joosteerbeek
franklin97355 wrote:Check out this Soldering Guide and redo your connections and see if that helps.
Thanks! Will try on monday. I'll let you know if that works.
bestazy
Post by bestazy »
Hi ! thanks for good tutorial, but I couldn't found question on my answer there
I was just wondering if u could put up a detailed picture on how to hook up another 8×8 led matrix and the code so it will work and can I use just 3 shift registers to do this ?
Thanks very much, bestazy
Return to “Ask an Engineer! VIDEO CHAT (closed)”
