Hello, first of all im a beginner in this field.
I want to make a project, creating a Bluetooth RGB lighting for mobility purpose. so i can adjust the color of the LED strip from my smartphone or a pc wirelessly.
I went over to the shop category, and i saw Adafruit NeoPixel Digital RGB LED Strip - White 30 LED - WHITE (https://www.adafruit.com/product/1376) and Adafruit NeoPixel Digital RGB LED Strip - White 60 LED - WHITE
(https://www.adafruit.com/product/1138) what is the different between it?
also i found the ADAFRUIT FEATHER NRF52 BLUEFRUIT LE (https://www.adafruit.com/product/3406) board which is exactly seems to be the correct boards for my project purposes. Can i use the RGB LED Strip to the board? Because i saw a boldline post about the product "You must use a 5V DC power supply to power these strips, do not use higher than 6V or you can destroy the entire strip" which turns out (maybe) i need a 5V DC power supply for the LED strip which i don't want to use any kind of a 'big shape power supply' for my project.
Which battery do i need for my project? do i need this POWERBOOST 1000 CHARGER - RECHARGEABLE 5V LIPO USB BOOST @ 1A https://www.adafruit.com/product/2465?
My goal for this project is having a RGB LED strip that can keep up for a minimum 12 hour of usage within a single charge. Also adjust the color and lighting mode (e.g pulsate, blink, breath, etc) from a smartphone and pc wirelessly
And what else you guys would like to suggest for my project?
Thank you in advance.
Bluetooth RGB
- Franklin97355
Re: Bluetooth RGB
One has 30 pixels per meter and the other has 60 pixels per meterI went over to the shop category, and i saw Adafruit NeoPixel Digital RGB LED Strip - White 30 LED - WHITE (https://www.adafruit.com/product/1376) and Adafruit NeoPixel Digital RGB LED Strip - White 60 LED - WHITE
