Hi
The connection between the GPS Board and a uFL to SMA cable (which connects to an antenna) seems a bit insecure to me. Could I solder this on or would this cause issues?
Can I solder on a uFL connector to the GPS Shield?
- tom1989
- devinganger
Re: Can I solder on a uFL connector to the GPS Shield?
Would not recommend it. That's two contacts, if I'm looking at it correctly. If you set up the proper strain relief and press down firmly, it should be fine.
