So, the particle counts are particles / 0.1 liter. Multiply by 10,000 to get particles / meter^3
What about the "concentration units"? I assume that's ug/meter^3...
but what's the difference between "standard" and "environmental"?
-thanks....
PM2.5 Air quality Sensor - Units?
- amhamilton
Re: PM2.5 Air quality Sensor - Units?
I was hoping for an answer to this same problem. Did you ever find an answer?
- solaria123
Nope.
I discovered that it can't actually detect particles > 3um; the numbers it reports are just estimates:
For my application, using the 0.5 micron counts. When the count exceeds 352, the ESP8266 triggers the HVAC to filter the air...
...but nothing about the Concentration Units. Maybe it has something to do with how it estimates the large particle distribution? Standard vs Environmental particle spectrum?From these measurements, we conclude that the Plantower PMS5003 is able to measure PM2.5 more
or less correct. With a suitable calibration, it may be calibrated to a reference instrument such as the
Grimm. The PMS5003 however is not able at all to directly measure large particles > 3um. When it
outputs PM10 values, these are pure estimates based on particle sizes it can measure (d < 3um) and
under the assumption of a broadly distributed particle spectrum. When the particle spectrum is not
containing PM mass contributions at sizes < 3um, the PMS5003 erroneously outputs PM10 values close
to zero.
These findings intensify the strong suspicion that low-cost PM-sensors, mainly produced by Chinese
manufacturers and designated as PM2.5 sensors but also reporting PM10 values, arenāt able to
measure particles larger than 3um and therefore solely extrapolate on PM10 values assuming a certain
particle distribution.
https://www.researchgate.net/publicatio ... _PM-sensor
- adafruit_support_carter
Check out the info I posted to @amhamilton's similar question here:
viewtopic.php?f=48&t=136528#p676664
