But we need to connect the adafruit data base to node js
How to do dt
Please provide some suggestions
Finger print sensor R307
- YASHASWINI
Re: Finger print sensor R307
How to do dt
How to do dt
- YASHASWINI
Can u tl me how to connect ardunio data server to node js
- adafruit2
we dont have any information on how to do that
- robin8895
I am using the same fingerprint sensor A307. So do i need to connect all 6 pins ot the four pins.
In case of 4 pins what should be the order either by colour of wire or by using just four pins.
Need help asap.
Need help asap.
- adafruit_support_carter
@robin8895 see here:
https://learn.adafruit.com/adafruit-opt ... th-arduino
- Eugene77
Hi
I have a similar problem
I can save new fingerprints in the sensor, but when I try to compare I get the error - Communicator Error
Thankful in advance for the helpAdafruit finger detect test
Found fingerprint sensor!
Sensor contains 3 templates
Waiting for valid finger ...
Image taken
Image converted
Communication error
- adafruit2
Eugene, what sensor are you using, with what board?
- Eugene77
I use fm2662m with Arduino Unoadafruit2 wrote:Eugene, what sensor are you using, with what board?
- adafruit2
what is fm2662m
- Eugene77
fingerprint sensoradafruit2 wrote:what is fm2662m
- Attachments
- 3.jpg (89.33 KiB) Viewed 2443 times
- 2.jpg (95.66 KiB) Viewed 2443 times
- adafruit2
what is the url you purchased that
