are there mods for these?
cv+gate in, for controlling as slave eg: from a 202 (would also need accent in...)
accent out, for controlling other/slave with accent input.
feasible/anyone done it?
cv+gate in, accent out
- isak
Re: cv+gate in, accent out
Hi
It's all in the wiki except for accent out.
There is an accent in though.
Cheers,
Isak E.
Cheers,
Isak E.
- jonen
I have a question regarding the cv in on the mod wiki:
It says to connect a SPDT switch (or switched jack) with one side connected to the tip of the external cv in jack and the middle to pin 5 of ic 11 and the other side of the switch to the point where R89, R88, R90 connect. However, in the schematics that point is already connected to pin 5 of ic11. So one has to cut that trace, right? I does not say so on the mod wiki though. Or am I wrong here?
- antto
yes, you'd have to cut that connection away
- jonen
Thank you so much for your answer, that clarifies things for me.
However, I was wondering, do you know if there is any other information available for equipping the xoxbox with a 'cv in' that controls the amount of env applied as well as another one that regulates the amount of accent (not accent off or on, but rather what the accent knob does).
I got curious as I saw this xoxheart turned into a euromodule: http://www.openmusiclabs.com/projects/x ... index.html
There is also more information http://wiki.openmusiclabs.com/wiki/x0x-heart, but I have trouble deciphering it.
