The circuit diagram shows 1 red from the led strips, mine has 2 reds and 2 black wires. How should they be connected?
Thank You,
Circuit Diagram
- adafruit_support_bill
Re: Circuit Diagram
Please post a photo of your board and a link to the diagram you are following so we can see what you are referring to.
- robinlewis
Re: Circuit Diagram
Hello!
The circuit diagram shows all blacks/reds going together, but I have an extra set of each on the LED strips. I know they're power but how to wire them?
Thanks <3
Thanks <3
- Attachments
- This is the divided LED strip.
- IMG_0886.JPG (323.68 KiB) Viewed 2343 times
- This is Becky Stern's Adafruit Circuit DIagram.
- Pro Trinket CD.png (486.79 KiB) Viewed 2343 times
Re: Circuit Diagram
The extra set of red/black wires is not needed for that application. (They are used when you have a large pixel installation with multiple power feeds.)
You can trim them back. Just be careful that you don't allow the exposed wire ends to short against anything . You can cover them with tape for added protection.
- robinlewis
Re: Circuit Diagram
Hi : )
Thank You SO Much for getting back to me!! I don' t think the clipped leads will short anywhere/anything with the setup. I will be back later with programming Q's.
Robots and Resistors,
Robin.
Robin.
