I just purchased the tv-b-gone kit v1. 2 and assembled it successfully. It is working principally perfekt but i discovered a strange problem. The unit is very temperature sensitive. It stops working at temperatures below 20 degree Celsius. The green LED only flickures two or three times and then it stops. After warming up everything works perfect. I tried this several times and it is obvious, that the thing doesn't run on low temperatures. The Micro Controller seems to be the reason. When warming it up with a finger, it works. Do you have any idea? Could the Micro Controller be defective?
TV-B-Gone Kit
Re: TV-B-Gone Kit
Please post some clear photos of both sides of your assembled board.
