Hi, I have a PowerBoost 500 Battery Shield and once the battery is plugged into the battery shield, the LEDs on the battery shield light up for a second and then become really dark.
I've tried a battery that works fine on another battery shield for troubleshooting and the same problem happened. Does anyone had a similar problem before?
PowerBoost 500 Shield Problem
- adafruit_support_carter
Re: PowerBoost 500 Shield Problem
It sounds like you have multiple shields and multiple batteries. Which batteries are you using? Can you post a photo of the problematic shield showing how you have it connected.
- TimmyDong
Yes I ordered three Lithium Ion Batteries - 3.7v 2000mAh and three battery shields. The other two battery shields work properly with the battery. Here is the picture of that problematic shield.
- Attachments
- WeChat Image_20190130143941.jpg (149.29 KiB) Viewed 2590 times
Is the switch on in that photo? It looks off. Curious what the LEDs are doing if you attach a charged battery and turn switch on.
Additionally, what the CHG and DONE LEDs do when you plug in a USB cable.
- TimmyDong
Without the USB cable connected, the 5V and Low LED only lights up when I plugged in the battery with the switch at the on position. Then 5V and Low LED becomes really dark. Nothing shows on the LED when I plug in the battery with the switch off.
Also, when I connect the USB cable, only the CHG LED lights up.
That all sounds as expected, except for the getting "really dark" part. Can you post a photo of that state showing the really dark LEDs. Sounds like they aren't off, just dim.
- TimmyDong
Sorry I should say it more accurately. The LED lights up really shortly once I connected the battery. Then it becomes dim and goes completely off.
Just to be sure - the batteries you are testing with are charged up?
- TimmyDong
Yes, I've fully charged the battery on another shield and put it back to the problematic one, still doesn't work.
Let's replace it. Send an email to [email protected] with a link to this thread and your order number and they can send you a new PowerBoost 500 Shield.
